Just following up on your posts to see if you resolved your issues.
Trying to keep up to speed, so far I understand:
You worked on switch #51 (Brick Wall Target) and reversed wiring & diode thinking the wiring was backwards
This resulted in every switch showing closed in the switch matrix except the right column & bottom row.
You reversed the wires to there original position, and there was no change.
When you unplug the playfield switches from the CPU, all switches show open
If you unplug switch number 51, then there is no change, all switches still show closed.
Is this correct? If so, could you please take a picture of switch 51 and post it.
Thanks,
Tom
