Hi there,
I've had Pinbits plastics protectors in my STLE since it was a couple of weeks old. The sling protectors look quite good in blue, with the hex-pattern cover over the inlanes. The problem I seem to have though, is that when you install the protectors and then the sling plastic, there is very little meat left on the thread of the post that the LED lamps screw to. Certainly not enough to put the lock washers back on, and every photo I've seen of them has the lock washers gone. So, no matter how hard I do them up, the lamp posts always loosen (and therefore change the aim of the LED lamp) after a couple of games. I'm not game to do them up too tight in case the plastic cracks or I strip the lamp post.
Anyone else experiencing this? Is there a post with a longer thread that I can substitute? The STLE manual lists a few different posts, but the original is 6-32 thread at the top, by the look of it, while the other longer ones are 8-32. Anyone know if there's a Stern (or perhaps Williams) part that might work?
I've toyed with the idea of using the larger post underneath and making some new lamp posts with my 3D printer, but would prefer of course to keep the original look.
Cheers,
FP
