Got a problem with my Long Opto on BSD Mist ball feature.
On the single switch test, switch #82 is open (Long opto switch), if I put the TV remote in front of the IR pickup it will go to closed, so I expect the pickup is picking up. Put a phone camera in front of the IR sender and I can see that I’m sending IR., but the pickup is not detecting the IR from the sender. NOW if I point a TV remote at the IR receiver in such a way that I’m not blocking the IR from the opto IR sender and press a button, switch #82 closes and stays closed, even after I remove the TV remote. Put my hand across the IR beam and the switch opens, remove my hand and it stays open.
At first I thought I had a connecter problem, now I’m wondering if it is an alignment or weak beam problem.
Any ideas?
