A while back I had a problem with two of my Flight 2000 displays not working. I had 175 volts but the two displays were dark. Someone advised that the glass needed to be replaced. I just moved those displays to players 3 and 4 and the game works fine. Just can’t have 3 or 4 players.
I’m in the process of replacing the connectors and headers on the working displays when I thought I’d try to check the bad displays again. I cranked up the voltage to 185 volts and the two displays sort of work. One shows a glow in the bottom (looks like a dot) and the other is trying to show numbers.
Do you think these are salvageable?
Bob
