Hi everybody, I'm having this problem with my new Baywatch (Sega 1995) pin. Hopefully anyone here can help out so I can start enjoying C.J., Jill, Erica and of course the Hoff!
When I bought the game, fuse F6 on the PPB was broken and none of the flashers working. So I replaced the fuse and then started a game: some flashers started burning brightly at the same time.
I then did a "Flasher test" from the diagnostic menu and all Flashers burn together. There must be some kind of short. I already measured all transistors (tip102/122, tip 36c) and they all tested out OK.
Where I should I look next? A short under the playfield? Some component on the board?
Thanks for any pointers!
