New! Dark mode!
(Topic ID: 168073)
Problem with 3 displays not working on pinbot
By Milltown
  • 8 posts
  • 4 Pinsiders participating
  • Latest reply 4 years ago by Milltown
#1 4 years ago
I just got my 86 pinbot.. player one display and player number ball are working.. player 2 3 and 4 are not.. it seemed when I looked the machines displays all worked and here they seemed to.. now 3 of them are not working .. any common issue with this I should look for ?
#2 4 years ago
Everything else on the game is fine.. I've disconnected and reconnected the ribbon cables and still nothing ?
#3 4 years ago
And if I swap at the board the 1 and 2 display connectors no 1 display will show what number 2 should display should show ?
#4 4 years ago
Figured out.. 3 bad displays .. the ol swap out.. any were to get individual displays cheap?
#5 4 years ago
PinballLife sells display glass at around $60 each. If you go this way, confirm you have the correct voltages on your power supply so you dont blow up the new displays.
http://www.pinwiki.com/wiki/index.php?title=Williams_System_9_-_11#Display_problems
Since you have to replace 3 of them, maybe its a good idea to upgrade to LED displays? The cost will be about the same and these will last a lifetime, plus you don't have the hassle of having to solder the display glass.
PinScore PS-10877-P
PinLED 10015
#6 4 years ago
If three are out, I would just get a whole new display and not mess with new glass.
http://xpinpinball.com/product/xp-wms10877/
#7 4 years ago
Maker sure the ribbon cables are ok. Then if the displays are bad, i would go with xpin...
#8 4 years ago
After a few tests.. 3,displays are,down.. and the one that works is changed... gonna get the led set.. for 210 bucks it seems worth it...
$ 18.99
$ 17.00
2,400
Sale Pending!
Bethlehem, PA
$ 54.99
$ 54.99
2,300 (OBO)
Mullica Hill, NJ
$ 175.00
Professor Pinball
$ 36.99
$ 9.00
$ 44.95
PinBoss Mods
