Quoted from baldtwit:if that's a hassle, you could also jumper the J2 - J4 switches in the add balls played circuit that are NC one at a time and see if that makes a difference when the score motor is running normally. That at least eliminates problems with those switches
I think very close now and found where the problem is. Need to do some further testing to solve it.
Try to explain what i did.
Jumpered J2 switch not the Y BL but the other no power line direct to the add balls play coil, for some reason when i start new game the hold switch does activated.
Then removed the jumper from the add ball coil, start the game, and before start to play, reinstalled the jumper and everything works fine.
Everytime starting a new game need to remove jumper first and before play the ball reinstal the jumper.
So during the startup process something went wrong. The problem is between J2 and the add ball coil. In between are the Z and Y switch, but seems to be ok, because are used in all other situation as well.
Hope you understand what i did
