Just got my first EM (Spanish Eyes) and am troubleshooting a small issue. In the game you need to light 1-2-3-4-5-6 by hitting standup targets. Each standup has two stacked switches. When you hit the target it should score 1000pts and then light an insert in front of the standup and at the bottom of the playfield. The problem I am having is that when I hit some of the targets it scores but doesn't light either light. Sometimes it works, other times I have to hit it 2-3 times. If I hold it longer it works. Looking at the schematic, this switch is supposed to fire a corresponding relay which locks both lights on. So it seems somewhat obvious that I am not getting a strong enough signal to fire the coil on the relay but not sure how to fix it. I have cleaned and set the switches and they seem to be working okay. Maybe corrosion on a plug? For someone more experienced in EMs I was thinking this might be a simple problem but before I start poking around more I thought I would ask.
IMG_20221028_153141375_HDR (resized).jpgScreenshot 2022-10-28 155330 (resized).pngScreenshot 2022-10-28 155400 (resized).png
