(Topic ID: 171669)
Pro football reel stuck
By Metalmanmiles
7 years ago
#1 7 years ago
New to em and having a problem, once i get the ball to the 10 yard line where you are about to score i get the touchdown but it does not reset the ball back to the start so everything i hit i keep getting a touchdown since it will not reset to the start. I think i need to clean the part that effects if it resets but i am new to this so i would like to know what to do and what to use to clean said area if i need too
#2 7 years ago
Not familiar with the specific game, but it's probably a 'stepper': http://www.pinrepair.com/em/index2.htm#steps
Prop up the playfield, and start advancing the light and watch for what mechanism moves (it might also be in the backbox). It'll have two solenoids, one to step it up, and one to reset it once you score. Make sure the reset solenoid is at least trying to fire when it's time, and it's not an electrical problem causing it.
#3 7 years ago
The AS stepper for the feature is the relay unit on underside of playfield that has its own jones plug so you can unplug it to adjust. There are hairpin clips on all relays to hold them on rail. Remove clip, unplug, adjust both switches on top and make sure stepper rotates every time you pulse coil with your finger. the 2 switches are the ones with leaves that make/break as the stepper rotates. If the stepper does not rotate there is a current thread on stepper rebuild.
#4 7 years ago
Here is a picture of the AS stepper (Right) as mentioned. It is located at the top of the playfield.
#5 7 years ago
Thanks for the help guys
#6 7 years ago
Would cleaning it help?
#7 7 years ago
Yes, would be a good idea to clean the unit by unplugging from the playfield. A clean up of the Jones plugs is also recommended.
Heres a link to give you some assistance. The 'AS stepper' is half way down the page.
#8 7 years ago
Sound good, will do
#9 7 years ago
What would you suggest cleaning with?
#10 7 years ago
rubbing alcohol. the 91% stuff. Use Q-tips to get where your fingers cant.
#11 7 years ago
Quoted from frb:
Do not use grease when you finish cleaning. It will soon collect dirt and gum it back up.
#12 7 years ago
Gotcha that's what I was thinking
#13 7 years ago
I had the same exact problem but I took that little AS stepper completely apart. I don't recommend that because if you can't get it back right the game will never work right, but you can take it out and send it to Steve at PBR and he will rebuild it for you. Try cleaning with 91℅ rubbing alcohol. That stepper is the heart of the game if it doesn't work right the whole game is off
#14 7 years ago
For a minute I thought this thread said: "Pro Football really sucks."
And, yes it does at the moment. Which is why people are not watching.
Back to the thread!!
#15 7 years ago
Quoted from eggbert52:
Yeah man it does, the ratings are down and all!
1,100 (OBO)
Knoxville, TN
$ 45.00
Tom's Pinball
850 (OBO)
Saratoga Springs, NY
900
Roswell, GA
This page was printed from https://pinside.com/pinball/forum/topic/pro-football-reel-stuck and we tried optimising it for printing. Some page elements may have been deliberately hidden.
