I'm having some challenges getting a WPC pin set for $0.75 per game and $2 for 4 games. No bill acceptor, just coins. Closest I can get is 4 for $2.25.
Any tricks to doing this?
Quoted from adalogue:I'm having some challenges getting a WPC pin set for $0.75 per game and $2 for 4 games.
I don't think that's possible. You can get 75 cents per play, 3/$2. Custom pricing, 1 click for each quarter, 3 clicks for a credit, bonus at 8 clicks.
Thanks Phish. Wouldn't that extra 2 clicks after the bonus "roll over" and give 4/$2.25 as well?
I'm trying to find a setting that is "even" and would produce the same accumulation if repeated, i.e.
6/$4.
Q1 = 1 click ($0.25)
Q2 = 2 click ($0.50)
Q3 = 3 clicks ($0.75 - 1 cred)
Q4 = 4 clicks ($1)
Q5 = 5 clicks ($1.25)
Q6 = 6 clicks ($1.50 - 2 cred)
Q7 = 7 clicks ($1.75)
Q8 = 8 clicks ($2 - BONUS - 3 cred)
Q9 = 9 clicks ($2.25 - 4 cred)
Quoted from adalogue:Thanks Phish. Wouldn't that extra 2 clicks after the bonus "roll over" and give 4/$2.25 as well?
Yeah, now that you mention it, I don't think that works on WPC. Sorry about that. If you crack the code, please let us know. It shouldn't be rocket science, but it sure is a pita doping it out.
Think I figured it out with a coworker.
1 quarter = 3 clicks
1 credit = 8 clicks
This gives 3 credits at $2 evenly, then bonus 1 credit at 8 clicks.
Should be able to do whatever you want with the right quarter/credit ratio.
Will try tonight.
It worked! But I see I mistyped it above:
1 quarter = 3 clicks/units
1 credit = 8 clicks/units
1 bonus credit @ 24 clicks/units
Hi, I'm completely lost trying to get the WPC Pricing Adjustments to bend to my will. I took plenty of math in school, just not "arcade math", apparently.
I have a Canadian $1 coin receptor in the left slot, and Cdn $2 coin receptor in the right slot. I'd like to price it so $1 = 1 credit, $2 = 3 credits.
Any advice on where to start?
[EDIT] Would I use .25 as the base coin size (default), and set it for 4 clicks for 1 play, 8 clicks for 3 plays? That won't work because each click is = $1 (or $2 if the right slot).
So changing the base coin size to $1.00 (instead of .25), then 1 click = 1 credit, 2 clicks = 3 credits? That doesn't seem to work, it always seems to register 1/4 credit for each coin dropped.
*bump*
Hi everyone,
I have a coin door question (I know, exciting). I have a two-slot coin door on my Judge Dredd (WPC DCS). Ive put in an Australian $1 coin mech on the left slot and an Australian 0.20c coin mech on the right slot. I'm trying to set the game for $1 per play, $2 for Supergame.
Ive tried messing around with Custom pricing and coin door options but I am stumped.
Any recommendations on how I can do this?
Everything in pinball is difficult I've gathered, but always satisfying when its solved.
ps I am using L7 ROM at this time.
Quoted from JediPimp:*bump*
Hi everyone,
My issue in the previous post was caused by using L7 roms when what I needed was LX7 which support custom pricing.
Might be the same for you.
This post has been helpful but when trying to set the credit clicks on my TZ, I'm going to A3 in the Adjustments menu. Going to 01 there is no choice for "Custom" so the other choices aren't unlocked/made available. What's up with that? I'm trying to set the game to .75 a game, 3 for $2. Any help is appreciated.
Quoted from Todd_Robinett:This post has been helpful but when trying to set the credit clicks on my TZ, I'm going to A3 in the Adjustments menu. Going to 01 there is no choice for "Custom" so the other choices aren't unlocked/made available. What's up with that? I'm trying to set the game to .75 a game, 3 for $2. Any help is appreciated.
What game ROM version to you have installed? There have been code releases that are freeplay-only home ROMs. If you have a home ROM installed, the coin play features will not be available.
Quoted from ForceFlow:What game ROM version to you have installed? There have been code releases that are freeplay-only home ROMs. If you have a home ROM installed, the coin play features will not be available.
Not sure which ROM. I will check. This game does have several options for the coin door. 2 plays for a dollar, etc.
This page was printed from https://pinside.com/pinball/forum/topic/pricing-adjustment-on-wpc and we tried optimising it for printing. Some page elements may have been deliberately hidden.
