JM is in the house. $800 held up. It's in unbelievably good shape. Cabinet has zero fade and hardly any wear. Had zero errors in the test report when I picked it up. Glass was filthy and play field needed a good wax but it had no holes or fade or chips or lifts or any problems. Really, the machine is in great shape. Replaced the balls and probably 10 lamps. It seems to play 100% flawless although I'm not familiar with the table to know exactly if something is amiss. I'll probably replace the flippers, they feel a little mushy.
Quick question: In the test report now (after the move), I do get a "Check Switch F5 'Ball In Hand'". I put my fingers up the underside of the glove in the Single Switch Test and F5 always remains open even though I'm pushing in the switch inside the glove near the magnet. I haven't even looked in the manual to see if that's the switch in question though, it just seems like "ball in hand" would be that. It's weird though, because the glove behaves fine in game and doesn't drop the ball unless I tell it to or the timer runs out. Maybe I'll start another thread on how to troubleshoot it further... but again, it seems to play flawless as far as I can tell!
I feel pretty lucky to have come across this.
