Kerry at Mantis has received the Stern sling shot lever that I sent him. He is aware. We wait.
Quoted from cottonm4:Kerry at Mantis has received the Stern sling shot lever that I sent him. He is aware. We wait.
Are there other/more parts we can try to get repro'd as well? They may not sell thousands, but with the popularity increase, now is a good time to ask and try!
Quoted from northvibe:Are there other/more parts we can try to get repro'd as well? They may not sell thousands, but with the popularity increase, now is a good time to ask and try!
Sure. The trick is getting enough people on board to make it worthwhile. I was working on possibly getting some brackets for Catacomb. At most, there were”commitments” for 10. This COVID hit and it all went up in smoke.
Quoted from bluespin:The displays are in different locations so he’ll have to make a light board and he might have to lengthen the display wiring harness.
Do they both use the two sound board set up?
Quoted from woody76:yea the credit and ball displays are for sure in different spots. I might could just cut a new light board. I think all the boards are the same.
The displays position between Big Game and F2K are similar. BG has the credit display up top while Fk2 is down low.
But there is enough extra wire in the F2K harness that it will work on BG without issue.
This is the F2K back rack harness at the credit display.
Here is the same credit display wiring lifted up. There is enough wire there that the F2K back rack harness will sub for a BG harness with out issue.
There is also enough wire for displays #2 and #4 that they can be moved around and also work on a Catacomb. I will assume the F2K harness will also work for Nine Ball and Seawitch but I have those 2 pins folded up right now and cannot verify.
A fellow pinsider got me a replacement kicker arm for my galaxy, but after installing I realized the fiber joint section was odd and it wasn’t moving nicely.... are there ways to cut/template or replacement parts?
Right side with issue
Left side without issue
Edit: not sure what “stock” should be but the right side looks like the fiber was installed backward...and now it is kind of messed up
The the bakelite piece out and see what's binding. The plunger fingers probably just need to be spread out a tad if they're pinching it. Or just might need cleaning on the pivot points.
Quoted from Chalkey:The the bakelite piece out and see what's binding. The plunger fingers probably just need to be spread out a tad if they're pinching it. Or just might need cleaning on the pivot points.
It looks like the fiber or Bakelite piece is backwards, so the flat side is on the pf side and the plunger comes out too far, at least that’s what it feels and looks like. It even may be that some broke off on that side...
Yeah on closer look the tip of the bakelite piece came off. Getting a whole new plunger might be easiest but I think you might be able to get just the bakelite from PBR.
Quoted from Chalkey:Yeah on closer look the tip of the bakelite piece came off. Getting a whole new plunger might be easiest but I think you might be able to get just the bakelite from PBR.
Yeah, I think you're right, the back side looks broke.
PBR sells the material in a strip to cut your own:
p/n: MAT-LINK @ http://www.pbresource.com/tools.html
PBL sells plunger w/links but is it the same as a stern flipper or williams one?
https://www.pinballlife.com/classic-stern-plunger-link-assembly.html
https://www.pinballlife.com/search.html?Search=plunger%20and%20link
Quoted from northvibe:Yeah, I think you're right, the back side looks broke.
Just buy a pair. Make sure you get the right length.
https://www.pinballlife.com/slingshotballshooter-plunger-and-link-2-18-plunger.html
https://www.pinballlife.com/slingshotballshooter-plunger-and-link-2-plunger.html
Quoted from northvibe:A fellow pinsider got me a replacement kicker arm for my galaxy, but after installing I realized the fiber joint section was odd and it wasn’t moving nicely.... are there ways to cut/template or replacement parts?
Your fiber is not installed backwards. The lever was not installed at optimum position at the factory. The lever and bracket have been install too bar inboard. The pivot point for the lever/fiber is way beyond the the axis of the plunger.
1) Reposition the lever bracket so the pivot point is directly under the plunger axis. You will get mush smoother plunger action
2) And get rid of that silly spring washer. It does not work like it is supposed to. You don't need it.
Quoted from cottonm4:And get rid of that silly spring washer. It does not work like it is supposed to. You don't need it.
I remember those, and removing them all!!
Quoted from Classic_Stern:...and the coveted S-plastic.
Quoted from Classic_Stern:...and with the butter inlanes it makes it flow like magic.
you shoud be in marketing!
Quoted from Classic_Stern:This is the Galaxy I just Sold. It was upgraded to 7 digits, all new clear plastics, MPU200 flipper style and the coveted S-plastic. You can see the changes in post layout to make it much more difficult and with the butter inlanes it makes it flow like magic.
What is the S-plastic?
I've never heard of "butter" inlanes. I assume those are the replacement plastic guides that lead closer to the flipper?
Quoted from cottonm4:Your fiber is not installed backwards. The lever was not installed at optimum position at the factory. The lever and bracket have been install too bar inboard. The pivot point for the lever/fiber is way beyond the the axis of the plunger.
The right side is the one I thought may be backward at first...but after comments and looking more. It seems broken. That left side one you quoted the pic of, yes, the E clip is missing and it does look off doesn't it. I'll back off the pivot and then align it straight! Thank you
I measured the plungers and they were 2-1/8". I'll order those for both kickers as the left one that is not broke, has some wear that may break it soon.
Quoted from jahbarron:you shoud be in marketing!
Exactly. The ball flow's without bounce onto the flipper and then you can hammer the spinner but also the right feed up to the saucer. LMAO!!! The game works as designed. The orbit and the right side up to the top.
Quoted from northvibe:What is the S-plastic?
If you look at the Galaxy playfield you can see a plastic that is formed to block the ball from going up into the left corner. By the collect Galaxy loop. We also have designed these for Seawitch on the left flipper to not thrash that plastic. We don't sell these yet.
Quoted from Classic_Stern:If you look at the Galaxy playfield you can see a plastic that is formed to block the ball from going up into the left corner. By the collect Galaxy loop. We also have designed these for Seawitch on the left flipper to not thrash that plastic. We don't sell these yet.
ahhhhh, now when i look closer I can see what you are referring to. I circled them in orange, in the attached pic. You going to sell those S blocker things? I ordered a new set of plastics, wonder if the new clear protector near the flippers extends to the flipper.....
galaxy (resized).jpgQuoted from slochar:I remember those, and removing them all!!
The spring washer is so the spring doesn't drive into the fiber link and cut into it. It does help in that regard especially in a coin op environment. Maybe not in a home environment. I've seen where the spring gets jammed into the fiber link without. Cause weird behavior. What is the problem with leaving ?
Quoted from Classic_Stern:The spring washer is so the spring doesn't drive into the fiber link and cut into it. It does help in that regard especially in a coin op environment. Maybe not in a home environment. I've seen where the spring gets jammed into the fiber link without. Cause weird behavior. What is the problem with leaving ?
All mine have the plastic link on them instead of the fiber one.
Quoted from northvibe:I'll order those for both kickers as the left one that is not broke
And now the ordering parts process begins. Lemme see, I don't want to pay $9.00 shipping for two $3.00 parts. So I will order some more stuff to spread the shipping cost. Oops. I just placed my order and I forgot to order this other part, too. I'll need to make another order. Lemme see, what else do I need....
Quoted from northvibe:I'll back off the pivot and then align it straight! Thank you
Do it this way: Have your sling shot parts up to snuff with all working smoothly. Then move that kicker bracket around and manually operate the kicker and plunger. You will find a sweet spot where the kicker, plunger and link work smoothly at full travel. That's where you want to be. Do all of this with out that washer. Then put the washer back on if you wish.
Quoted from slochar:All mine have the plastic link on them instead of the fiber one.
Oh. Yea, I think all of the games past like Big Game went to Plastic. They probably kept with the washer. I will be looking.
Quoted from cottonm4:And now the ordering parts process begins. Lemme see, I don't want to pay $9.00 shipping for two $3.00 parts. So I will order some more stuff to spread the shipping cost. Oops. I just placed my order and I forgot to order this other part, too. I'll need to make another order. Lemme see, what else do I need....
LOL. I'm already on my 3rd or 4th order between PBR, PBL and Marco for parts...one of those. I should just need these, then that i just the top side, now the underside needs this...then you get deeper, ohhhh I need more... yup. probably paying more in shipping than I paid for the game :-p Um not too bad but PBL doesn't do USPS atm so fedex/ups is minimum $15 shipping :/ sooooo mind as well order up as much stuff.
Quoted from Classic_Stern:Oh. Yea, I think all of the games past like Big Game went to Plastic. They probably kept with the washer. I will be looking.
I reassembled my Freefall in stock form. It does not have the washers.
A9A82C15-CA14-4AC8-97A1-43DEB137A239 (resized).jpegQuoted from Classic_Stern:This is the Galaxy I just Sold. It was upgraded to 7 digits, all new clear plastics, MPU200 flipper style and the coveted S-plastic. You can see the changes in post layout to make it much more difficult and with the butter inlanes it makes it flow like magic.
I get the S plastic. And the in-lane plastics stop the ball from bouncing over. Does anyone have the drawings for these mods? What is MPU 200 flipper style?
Quoted from SR230CC:I get the S plastic. And the in-lane plastics stop the ball from bouncing over. Does anyone have the drawings for these mods? What is MPU 200 flipper style?
This is the MPU 200 style flipper assembly. I cannot find a link to the MPU-100 style flipper assembly.
https://www.pinballlife.com/full-flipper-assembly-for-classic-stern-machines-031980-to-021982.html
MPU200 style should really be called offset 2nd generation instead, as the first games did not have this style (meteor, galaxy, ali). Sometime during the production of Big Game it changed from the flat Chicago coin 1st gen style to the offset style pictured.
D
Sorry haven't gotten back with you but what Cotton ; slochar said above. Now you can replace only the link, paw and make sure you use a plastic flipper for less weight in the MPU100 assembly and keep the old spring if it's loose. All the new springs do is add bounce with the new flipper links cause they are typically to strong of a "K" value. use old springs if you can. This will maximize flipper power along with changing the coil to an S450. Just make sure the flipper plate is firm on the field. I always fill in the holes with a dowel on all my restored games and retap every flipper plate screw so it's firm. This ensures solid performance over the life you will have the game.
For post configurations look at the field. The 2 feeding the flipper use larger diameter. So it's hard to go down X,Y the outpost is a black nub you use to hold on plastics. Force that over the post. This creates a rigid outlane post but doesn't metal on metal the ball. this make the game hard. Also the lane guide remove the solid edge into the center of the field. This helps create an extra hard game.
The 7 digit ROMS are on IPDB I think. You have to add 1 wire to the harness
Quoted from slochar:MPU200 style should really be called offset 2nd generation instead, as the first games did not have this style (meteor, galaxy, ali). Sometime during the production of Big Game it changed from the flat Chicago coin 1st gen style to the offset style pictured.
Yep, I have a big game with offset and a populated playfield with 1st gen.
Quoted from Classic_Stern:D
I have mine setup this way. I think I need to have 2 levels for my in-lane plastics. I had the bigger rubber to make the X and Y harder but changed it back for guests to play. I will check out what flipper assemblies I have.
83A41562-D7B6-454F-898E-DC2F680DDE12 (resized).jpegQuoted from SR230CC:I have mine setup this way. I think I need to have 2 levels for my in-lane plastics. I had the bigger rubber to make the X and Y harder but changed it back for guests to play. I will check out what flipper assemblies I have.
Yea, Having that set up makes the game really easy to feed the flipper lanes. You can add in larger white rubbers and shave off the solid edge on the lane guide and add a larger rubber where the lane guide is. You want the X,Y such that you have to bump to make and set the tilt such that it's not easy. The outlane post then gets the black rubber. Need white to make it very challenging.
Should I do it?
6,301 Flight 2000's were produced.
1,223 Cheetahs were produced.
All I need to do is get this Cheetah play field restored, buy a BG Resto Cheetah back glass, and build a Cheetah lamp board. Lamp boards can be made easy to swap.
1) Swap lamp boards
2) Swap MPUs
3) Put the Cheetah back glass in
4) Restore the play field
And BOOM. An F2K turns into a Cheetah---with a blue cabinet.
Quoted from cottonm4:Should I do it?
1) Swap lamp boards
2) Swap MPUs
Tough call, both awesome games. But I’d go for it!!
Quoted from Tsskinne:Anyone else got big game In lanes that look like this
I did not see what you were talking about at first. This BG has those little brackets in the sides that someone talked a couple of weeks ago about those brackets showing up on a sales flyer.
Can you give us some close up shots, please?
Quoted from cottonm4:I did not see what you were talking about at first. This BG has those little brackets in the sides that someone talked a couple of weeks ago about those brackets showing up on a sales flyer.
Yeah driving home with it now I’ll photograph shortly
1) Swap lamp boards
2) Swap MPUs
Yes, Turn it. There's ton's of F2k's. I've parted a bunch before parts were available to restore.
DSCF8958 (resized).JPGQuoted from Classic_Stern:Yes, Turn it. There's ton's of F2k's. I've parted a bunch before parts were available to restore.
Well, it looks I am going to plan to bring Keith a Cheetah play field shortly. It was populated play field when I bought it. I have the wiring and everything to put this play field back together.
Quoted from cottonm4:Well, it looks I am going to plan to bring Keith a Cheetah play field shortly. It was populated play field when I bought it. I have the wiring and everything to put this play field back together.
I was going to say... the PF harness, 5 banks drop target would be a challenge to get if it was an unpopulated PF Who are you using for PF resto?
Quoted from hisokajp:I was going to say... the PF harness, 5 banks drop target would be a challenge to get if it was an unpopulated PF Who are you using for PF resto?
we use Keith Holbrook, he has done complete games and playfields for me and does really nice work.
Cottonm4
What do you plan to do with the F2k playfield. I bought one and the field is somewhat beat.
Quoted from Classic_Stern:Hey, Make sure you plan on heading this way and stop by if you go to Keiths.
Thank you. You saved me from inviting myself . I'm waiting to hear back to see when is a good time to bring the play field down.
Quoted from FlipperFanatic:Cottonm4
I have not thought that far ahead. Send me a PM and so we can shake hands. You can have 1st dibs if I do this.
Adding to the weird question... anyone know a good replacement for the spring holding both metal piece together of hole kickout? Like in Ali, Nine ball, etc... I looked through the 2 Stern parts manuals but i could not find that assembly, nor did any springs from my random stock matched.
It is pretty sick and hard, about 1 inch long.
my working BG does not, but I just checked my extra populated BG playfield i got and it has these.
One other thing I would like to hear about with this pin. When I bought my BG Resto repro Big Game back glass he sent me one made of 3/16" thick glass and claimed this is what his Big Game had.
I have owned 2 Big Games and I have several other classic Sterns and I have talked to pinside BG owners but no one has a 3/16" back glass. So I am curious what the glass on this one is like.
This page was printed from https://pinside.com/pinball/forum/topic/price-check-1980-sterns-quicksilver-stargazer-seawitch/page/72 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
