Several months ago I made a post of how you could swap Bally drop targets into a Stern drop target assembly. I did that today and here are the pics.
Dragonfist is supposed to have red drop targets. You cannot buy red drop targets to fit a Stern. But you can buy red drop targets to fit a Bally. The pics that follow show this swap in action.
Here is Stern drop assembly.
Here are 3 red Bally drops and one white Stern drop. The first thing you will notice is that the Bally drops are rather square up top. They do not have the small side curve as the Stern's do. This is cosmetics. I could make the sides curve like the Stern but I would have to destroy another drop target to make one drop look like a Stern. These are only $3 each. It would cost $27.00 to do this.
Here is close up of the two styles of drops.
1) Bally has a half-moon land just below the target's lower edge. Also, if you look down you will see the boss where the spring attaches is little different.
2) Stern made its lands a little different than Bally. You can see the long skinny piece of plastic extend about 5/8" below the lower edge of the target. And the boss where the spring attaches has less meat around the hole for the spring,.
Keep these two different styles of target lands in mind. Operationally, both styles of lands operate the same. But Sten's style does it better. I'll get to that in a minute.
The teardown.
This is where I remove a white drop target and swap with a red one.
The Stern target has a piece of angle bracket that holds the targets in proper position.
From the top and looking down, you can see the land of the targets landed on the angle bracket. This is Stern's way of doing it.
For Bally, with the half-moon land at the bottom of the target, the bracket that holds the target place needs to be reversed.
This is all you need to do to use Bally drops in a Stern assembly. The reverse also holds true. You can install Stern drops in a Bally assembly. And you reverse the bracket where the lands sit.
Here is the drop installed with red drops. As mentioned, the profile on the Bally Style drops are different than Stern; That could be fixed with a little bit of work. And while they are red, I don't know how close this red is to the original red.
This is where the rubber meets the road. How do they work? The answer is: Not worth a shit. NWAS for another new acronym plagued world.
They can be knocked down---with difficulty.
So, as I fairly much thought, I will have to modify the lands. There is just too much plastic contact for the drops to release quickly. For the next time through, I will trim back the half-moon land and make a smaller land area. Perhaps with less material on the land the drops will release a little easier. If that does not work satisfactorily, then I will trash an extra drop target for material to extend the Bally land down lower like the Stern drops are.
So, they work but need improvement. Making the improvement will not be hard to accomplish. I'll be back when I make that mod.
My question is why do the Bally targets so hard to drop? I have noticed any Bally I have played to have lousy working drop targets.
