(Topic ID: 225496)
Stern Electronics Club (1977-1984).
By Mitch
1 year ago
  • 2,441 posts
  • 203 Pinsiders participating
  • Latest reply 1 day ago by BrianBannon
  • Topic is favorited by 101 Pinsiders
There have been 733 images uploaded to this topic. (View topic image gallery).
7 key posts have been marked in this topic (Show topic index)
There are 2441 posts in this topic. You are on page 48 of 49.
#2351 29 days ago
Have you repinned the upper left connector on the MPU? That's what it looks like to me...
#2352 28 days ago
Hi guys, finally joined the club this weekend, added a Dracula to my early SS lineup. Current laundry room line below. Dracula is not powered on as I'm waiting for some parts to fix some wiring hackery.
#2353 28 days ago
Also looking for a couple plastics for Dracula. Missing the small one over the kick hole, and the big top left one has a couple major cracks. The two shown in this pic, not my machine, from gallery here.
#2354 28 days ago
Not sure if this will help anyone, but I finished up the Stern Magic LED conversion the other day. I had several bulbs out (8). I found and replaced 3 bad SCRs on the LDB. This fixed all but 4 lights. Using low cost Comet LEDs and the seigecraft adapters. I was using all warm white except the 4 that were having issues. I was using cool white in them because they were the 4 inserts I thought looked good with cool. I usually use cool under green, purple and blue inserts. Anywho, on a complete whim of curiosity, I swapped in warm whites in those 4 and they all work fine. I haven't had an issue mixing colors before, so maybe the way Magic is wired had something to do with it. Just a weird one I figured I'd share.
#2355 28 days ago
Does anyone know if the little button rollover switches from Stars have been repro'd or available anywhere? Mine are looking a bit haggard. thanks
#2356 28 days ago
Quoted from MikeS:
I believe Pinball Resource has them on this page.
http://pbresource.com/rollobut.htm
#2357 28 days ago
Quoted from treborlicec:
thank you! yes, I think that top one is it. I should have known to check with PBR.
#2358 28 days ago
Not sure if this will help anyone, but I finished up the Stern Magic LED conversion the other day. I had several bulbs out (8). I found and replaced 3 bad SCRs on the LDB. This fixed all but 4 lights. Using low cost Comet LEDs and the seigecraft adapters. I was using all warm white except the 4 that were having issues. I was using cool white in them because they were the 4 inserts I thought looked good with cool. I usually use cool under green, purple and blue inserts. Anywho, on a complete whim of curiosity, I swapped in warm whites in those 4 and they all work fine. I haven't had an issue mixing colors before, so maybe the way Magic is wired had something to do with it. Just a weird one I figured I'd share.[quoted image]
The spots giving you issues, were they not working at all? Or strobing badly?
-Hans
#2359 28 days ago
Quoted from HHaase:
-Hans
Totally off. Issue was happening with and without your boards, so I know it has to be something with the game or the LEDs themselves.
#2360 27 days ago
Does anyone have a fix for the rivet coming off on the lockdown bar lever? Can it be attached with a nut / bolt if the receiver is removed?
#2361 27 days ago
Quoted from Chalkey:
Actually, the small rivet piece you are holding in your hand looks like one of the rivets to hold the receiver and the slider bar together. Your lockdown bar handle comes fastened with a machine screw and nut from the factory.
You will need a couple of washer spacers.
Since it looks like you don't have the proper spacer washer with a shoulder, I would suggest drilling the hole in the receiver to a larger size to match the hole in the handle. Get a machine screw, some washers and a nylon locking nut so you can adjust tension and it all should work fine.
#2363 24 days ago
You have a nice looking Seawitch. I would like to offer a correction. Your back glass was reproduced by John Greatwich and not CPR as your ad states. CPR makes Seawitch plastics, but not the back glass, as far as I can tell.
#2364 24 days ago
Thanks, yes its very nice. It is a CPR. Check their website under back glasses, you'll find it.
Quoted from cottonm4:
#2365 23 days ago
What is this nail for? What purpose for this?
I just noticed that all of my Stern cabs have this short nail hammered into the cab just to the left of the coin door.
Catacomb
Nine Ball...and the NB cab I have converted to a Quicksilver had one as well.
Seawitch
Dragonfist. The nail is gone but the hole is still there.
Meteor has a nail as well. Not pictured
#2366 23 days ago
Catacomb
Seawitch
That’s so that when you swing the coin door wide the coin plate doesn’t put a big old dent in the cabinet. Bally does the same thing.
#2367 23 days ago
Quoted from dothedoo:
Yeah. Bally one was bigger and hit the coin return button.
#2368 23 days ago
Quoted from Whridlsoncestood:
Just checked my Bally and yep, there it is alright.
Never noticed it really as it is rather inconspicuous.
#2369 23 days ago
Quoted from rollitover:
You’ll notice it when you restore a cabinet and then don’t install one back in and open your coin door into your fresh paint job ... I mean probably
#2370 22 days ago
Is there any way to adjust the kickout direction from the hole in Dracula? Mine is shooting the ball into the pop bumper cap adjacent to it and then into the glass. I tried bending the tip a bit, and bending the wire post sticking up, neither seemed to have much of a effect, when the ball comes to rest in the hole it is all the way to the right side and gets kicked that way no matter what. I can see where it used to hit the playfield by the wear marks, but it not longer shoots there. ideas?
#2371 21 days ago
Quoted from BorgDog:
Is there any way to adjust the kickout direction from the hole in Dracula? Mine is shooting the ball into the pop bumper cap adjacent to it and then into the glass. I tried bending the tip a bit, and bending the wire post sticking up, neither seemed to have much of a effect, when the ball comes to rest in the hole it is all the way to the right side and gets kicked that way no matter what. I can see where it used to hit the playfield by the wear marks, but it not longer shoots there. ideas?[quoted image]
I thought the coil stop is adjustable. I did a service call on one, and the coil stop had a
brass screw with a brass nut to adjust the throw of the plunger.
#2372 21 days ago
You will need to remove the screws that are currently holding the saucer into position. Make new marks carefully on where you want the kicker to shoot to and drill new holes. You should consider and may even have to fill the old holes with dowel rod and clean them up.
#2373 21 days ago
Quoted from vec-tor:
I'll take a look, thanks.
screws? they be nails, but yes I had considered this but thinking I may need to move the whole mech as well.
#2374 21 days ago
Just a thought, but couldn't you just swap in a lower strength coil?
#2375 20 days ago
Quoted from La4s:
maybe, but it's more the direction it's going than the strength, although it is a bit strong to be hitting the glass like it does. I think with a lower strength coil it would still be hitting the pop bumper though. I'll see if I can find what's supposed to be there and see if what I have matches.
#2376 20 days ago
I've been considering moving my Barracora kickout for the bottom lock. It usually kicks sdtm and you have to work to save the ball.
#2377 20 days ago
got a altek board in my Quicksilver but can't get high scores to work all I see is this: tried changing the dip switches to no avail...
any ideas?
#2378 20 days ago
You try the memory clear function? Does it work fine in another Bally/Stern?
#2379 20 days ago
Quoted from 8bitrobo:
I installed a protector on my Stars from Beehive Pinball. He included spacers to put under the drop targets to make them level with the protector. Plays great, never had any problems with it on. Now I can procrastinate fixing some of the cupped inserts.
So you put the beehive protector over the cupped inserts?
Does it work well? I was wondering if I would have to fix those before putting on the protector.
#2380 20 days ago
Yeah probs just needs a memory clear.
Protectors work great to neutralize the effect of cupped inserts.
#2381 20 days ago
Quoted from NeilMcRae:
any ideas?
Yeah. Clear the high scores in the menu. Clear all the audits to be safe and start fresh. Usually fixes that.
#2382 20 days ago
OK. I guess the plastic piece that is there is nailed in. But I was talking in terms of the entire mech assembly, which I would think is screwed in, needs to be rotated at little bit. And you would have have to pulls the nails and rotate the plastic pice to match.
#2383 20 days ago
thanks will try on Thursday.
#2384 20 days ago
any ideas?
Does it go into attract mode,and can you start a game? If not, I suspect that the game dipswitches are set for a Stern game with multiball. You will something similar to this on the displays with a Stern multiball game, if it can't find the other balls.
#2385 20 days ago
any ideas?
There are 2 jumpers in the upper left hand corner of the Alltek MPU. There are 3 jumper pins for each jumper connector. For Bally, the jumper needs to be on the 2 right most pins. For Sterns, the jumper needs to be on the two left most pins. It is in the instructions. This is for all MPU-200 pins.
I won't say this is your problem or even if it will cure your problem if you need to swap your jumpers, but they do need to be on the left hand pair of pins
The one classic Stern I bought from a retailer was supposed to have been play tested before it was shipped to me. When I received that pin it played like pure shit. I don't know how any same person could have said it was playing well. It had an Alltek MPU installed. I looked and the retailer missed swapping those two jumpers over to the left, but he still shipped me something he said played well. So, if you missed the jumpers, you are not the only one who has---even the "pros" missed it.
#2386 20 days ago
any ideas?
The other thing is if the board was in another game before this Quicksilver, you need to do a factory reset, or the new game can act wonky. See the instructions to set the dips for a factory reset.
#2387 18 days ago
Does anyone Know who the person is that made the Wonder Woman backglass and plastics for the Lectronamo that was at Expo?
#2388 18 days ago
Quoted from MooButt:
https://backboxpinballpodcast.fireside.fm/18
Don't forget the custom side art, too.
#2389 17 days ago
The side art was cool. She did a nice job on the game.
#2390 17 days ago
I have a beehive over cupped inserts on a Flight 2000. Completely flat now.
#2391 17 days ago
Quoted from ArcadeRaid:
What is a beehive?
#2392 16 days ago
What is a beehive?
Playfield protector, I just found it last week. Gonna order one for my meteor.
https://beehivepinball.bigcartel.com/product/playshield-playfield-protector
#2393 16 days ago
I have one on my Meteor. Works great over cupped inserts.
#2394 16 days ago
Quick question. Are all early stern cabinets the same? Would a stingray cab work for my galaxy?
#2395 16 days ago
I have the same thing from Beehive - made my game playable again.
#2396 16 days ago
Yes, I did have the adjustable coil stop, and adjusting that helped the power, but what ended up fixing the direction problem was adjusting the switch. It was pressing so hard up that the pin on it was forcing the ball off to the side resulting in the ball being fired into the pop. everything in Drac now working well, thanks everyone for the tips and ideas.
10
#2397 16 days ago
Just for the record.....
There are now Tech Charts available for all the M-100 games.
You can find them in the Tech Chart section or the Stern Electronics section on my website http://www.inkochnito.nl
I also added all the Tech Chart information to the Pinwiki site, http://www.pinwiki.com/wiki/index.php?title=Bally/Stern#Stern
Just click on the game name.
#2398 15 days ago
Quoted from Inkochnito:
Thank you
#2399 14 days ago
Looking for the start button on the coin door. Has anybody repro'd these or anybody got a used one they want to get rid of? I just picked up a Flight 2000 and the start button on the coin door is missing.
#2400 14 days ago
Quoted from dmartin244:
Want to sample a 3D printed one?
$ 5.00
Doc's Pinball Shop
Third Coast Pinball
$ 6.00
Siegecraft Electronics
San Tan Valley, AZ
$ 49.95
Pin Stadium Pinball LEDs
