Have a Seawitch where a prior owner rebuilt flippers using all new assemblies. I noticed that my lower left flipper was all but dragging on the playfield, while my right flipper had a nice gap. I pulled both flipper bats off and found that the right flipper has, from what I can tell the (more?) correct flipper bushing *and* on the top side, a small spacer that goes between the flipper bushing and the flipper. It's roughly 11mm outer diameter and ~1.5mm thick.
The left side bushing appears to be incorrect and ironically was a bit longer than the one on the right side, but without the spacer on the top side, it seems able to go above the plane in which the bottom side of the flipper moves. That is, the bottom of the flipper sits lower than the top of the bushing.
I have another bushing that matches the right side, so if install that on the left side and 3d print a matching top side spacer I think it will work well.
However -- Is there normally a top side washer on Stern games? If not, I'm assuming that means the right side bushing is technically too short, even though it works well with the spacer. (And most likely due to how the new flipper assemblies are put together, as you can see under the plates that the bushings originally would've screwed directly into the wood.) Are these new assemblies meant for Stern games or has someone sort of retrofitted these to work? I can see there are old holes under the flipper plate not used by the new one.
For reference, here is the right side flipper mech (plates have holes meant for bushings to mount into):PXL_20230224_051757909 (resized).jpg
And how the right side bushing comes through top side (it's roughly flush, if not ever so slightly recessed): PXL_20230224_051809781 (resized).jpg
And right side flipper with spacer. (You can see how the bushing would break the bottom plane of the flipper without the spacer.): PXL_20230224_051844833 (resized).jpg
