A while back I asked if anyone would benefit if I were to do a live demo/real time?/ of some switch matrix stuff to help some of you understand how to read the switch matrix. Some of you raised your hands.
Here we go. We are going to do Seawitch. We are going to map 8 items: We will be looking at the wiring for the (1) top thumper, (2) left thumper, (3) right thumper, (4-5 ) both slingshots, (6) the left hand out lane, (7) and the top left stand up target. And where is #8?
With this play field I have marked all 7 items with orange tape.
This is the switch matrix drawing. We are going to run the brown/white wire coming from connector MPU A4-J2-2 ( I have used purple/white wire instead of the blueprint call out of BRN-W. You will need to use your imagination ).
Here is the drawing with the BRN-W wire hi-lighted in pink. This is column ST1 B.
Here is the lower side of the play field. This shows the BRN-W wire making the run from the (3) pops and then it moves down to the (4) right sling shot and then crosses over to the (5) left sling shot. I have the five switch points marked with orange tape.
And here are the remaining (3) items.
First, the drawing. Now we are working on Row I-1. On this row, there are are the (6) left out-lane, (7) the top left standup target, and the (8) top pop. The top pop is # 8 and is mentioned twice as #1 and #8 because both wires on the switch matrix are located.
You have just ran one Row wire (BRN-W) and one Column wire (grey).
This is how the switch matrix works. One wire at a time. And then, of course, you have to figure out the cleanest way to run the wires and there is no one right way. Every Star Gazer build I have looked at here has had the wires run a little bit different.
I hope I have been able to put this together in a clear and concise manner so it can be easily understood.
Does this help?
Does anybody need to see more?
