A few weeks ago I asked if it would help anybody if I were to make up a switch matrix or solenoid matrix "in the flesh". 1 or 2 people said it would help.
Here is my first try at this. I'll do something with a play field when I get more time.
Since so many ask to see how the flipper solenoids are wired, I figure this might open some doors and help with understanding the matrix drawings.
This is the solenoid matrix for Quicksilver (To my knowledge, the flipper wiring is going to be the same across all of the classic Sterns).
We are going to home in on the upper left portion of the solenoid matrix. But before I get started, this portion is taken from the Seawitch manual. The EOS switches are drawn incorrectly on the Quicksilver drawing above. Study these two drawings to see how the EOS switches are drawn. Once again, the EOS switches are drawn incorrectly in the top drawing.
So, let's start with the diode which can be confusing to understand when you are new to this stuff. Diodes have a silver band embossed on one end of the diode. This band is represented by the small triangle and line on the drawings.
Here it is in real time ( NOTE: On the left lug I have soldered on both a green and an orange wire for visual purposes only. Left is green flipper wire and orange is right flipper wire). Yellow wire is for the EOS switch.
Here is how it is represented in the drawing ( Yellow color does not usually scan very well so i have the EOS switch highlighted in both yellow and some orange.
These 2 wires, the green and the orange travel up to the SDU to A3-J1-8 ( green ) and A3-J1-9 (orange).
OK. That's it for the flippers. Once you understand this you will never need to ask for pictures on how the flipper solenoids are wired.
There are 2 more items that can be talked here.
Let's talk about the black/blue wire that is at SDU A3-J1-5.
That black/blue wire at A3-J1-5 is the trigger wire for the center drop target.
Over on the right side you see the Blue-white wire hi-lighted in blue. That wire is called out for connector A2-J1-6
The rectifier board is called A2. The connector is called J1. And pin #6 is the sixth pin to the right.
That's it for the flippers wiring.
If this has helped you out, give it a thumbs up so I know I am on the right track. When I get to a play field it will be along these same lines.
If you see something I have done wrong, please speak up so I an make any corrections. There is already enough stuff wrong with Stern drawings that I don't need to be adding to the mix.
This is a road map I drew up for the circuit boards.
The MPU is called. A4 (multi processor board )
The SDU is...........A3 ( Solenoid Driver board )
The LDA is ...........A5 ( Lamp Driver board )
Rectifier is............A2 ( rectifier )
So, if I say to you, that such and such wire goes to A5-J1-1, you can see that A5 is the lamp board. And that connector J1 is in the upper right hand corner. The keyway blocker is the #20 pin. And pin #1 is on the bottom. And there are 28 pins total.
So now, go find A3-J1-1. Pin #1 is on the top. And there are 9 pins.
