Quoted from BorgDog:Homepin made a replacement Bally transformer that I think would work, but I don't see for sale anywhere at the moment.
I was thinking about trying to find an alternative using switching power supplies like new machines and led displays so no need for high voltage. I'm probably over simplifying or missing something, but I see 43VDC (coils), 5.4VDC(controlled lamps), 11.9VDC(logic?) and 5.9VAC(GI). Is there a reason that the GI could not be DC as well instead of AC? If so, I think all of those should be easily doable.
Maybe someone smarter than I can tell me what I'm missing with that?
This playfield does have all the wiring on the back, so that's a start.
1) Playfield wiring is most of the battle.
2) Almost any Stern or Bally single level standard playfield cab will work. If using a early Bally cab, the playfield will plug right in to the rectifier board. If later Bally (-54 rectifier) you will have to make a minor adapter or cut off the plug.
3) Sound is easy- SB300 from Andrew which requires 12v and ground, plug to speaker and plug to speaker control.
4) Don't get too tied up on transformers- The early "small" unit from Stern works fine and there is a bizillion Bally units out there.
Pictured is Seawitch in Bally Pacman cab with Star Trek head with Flash Gordon style hinged neck. Altech MPU and SDB, Bally lamp board, Mr & Mrs Pacman transformer, Bally displays and Pacman wiring harness.
A work in progress but I can play, though with no sound at the moment since the post office has misplaced the SB300
3e3518d0c4cfb788b8452ada014e5c53f83df1b3 (resized).jpgb0e8c45c0d7e79837aea7bedaaf6281791d14554 (resized).jpg
