Quoted from Pinball_Nate:My coin door lockout mechanism is gone, but I am guessing that as long as the correct wires are attached with the diode in place, the circuit should still be working correctly. Is that a correct assumption?
Pic #1 is correct. The lockout and knocker are wired in parallel. You can disable one or both and can still play.
Pic #2 is correct.
Pic #3 is not correct. Y-R also feeds the memory clear switch.
Pic #4 Chute #1. Should have 2 R-Y wires soldered to a tab. One of those R-Y terminates the circuit and the other R-Y wire daisy chains to Chute #2.
You need your digital multi meter. The blue wire feeds from A4-J3-9. That is MPU connector J3 on lower right hand side of MPU. Pin #9 should have a Blu wire connected. Check continuity from the capped blue wire to A4-J3-9.
You have one R-W wire and another wire not R-Y on the Chute #1, as well as the B-W wire. This s where it get fun. You need to figure out where this B-W wire and the not R-Y wire are coming from. Someone else may have an easy way to figure out where these wires are coming from, but there are times when all I know what you do is start cutting wire ties so I can physically touch, few, and chase the wire.
And someone has wire nutted the 2 reds and a blue together. You are going to have to physically chase this stuff and see where each wire goes: Which connector, which board and which pin. If you have an idea where they come from or go to then your multi meter might be able to save you some work.
You can also start checking at the coin door connector since it is sitting at your right hand.
This is the coin door connector on why Seawitch. I pulled the tie wraps for reasons I cannot remember. But it works.
Let's get your chute situation cleaned up before proceeding. Here is what I suggest. The coin door can be removed by removing the 3 nuts and carriage bolts that attach it to the cab. I would put the coin door on a bench so I can check it out in a relaxed position. There are several solder joints on one chute tab that are plain ugly.
I would put my fingers on the R-Y wire at the coin door connector and trace it to the 3 chute switches, the credit button, and the slam tilt switch. And then clip new ends, twist the daisy chain together and then re-solder until you have the R-Y wire going correctly to each switch. Once that is out of the way, then go after that capped blue wire on Chute #1; You should be able to trace it from the coin door connector and find it somewhere in your harness; Solder the blue wire.
Hopefully, you have enough wire in your harness to do this but with those wire nuts I see, you may have to go buy some wire. Or some shrink wrap tube. DO NOT cut your wires too short.
You do not need to remove the coin door but it will make your job easier. Once you have touched all of the wires in the coin door, I"m thinking it will help your understanding if you find yourself inside the cabinet chasing a wire.
If something looks like it has good solder joint, leave that alone.
5 of your switches are on the coin door. The 6th switch is the tilt bob on the tilt board but the tilt bob is also on this same R-Y circuit.
You have a R-Y wire that is daisy chained to 6 switches. Each switch has another wire associated with it. For your switches we new only talking 7 wires: R-Y, Y, Blu-W, R-W, Brn-W, Blu. Look at it that way. ( #7 The Blu-Orange wire is for the tilt bob and not located to the coin door.
PM me if you have any questions.
