(Topic ID: 225496)
Stern Electronics Club (1977-1984).
By Mitch
  • 6,029 posts
  • 330 Pinsiders participating
  • Latest reply 10 hours ago by cottonm4
  • Topic is favorited by 179 Pinsiders
10 key posts have been marked in this topic (Show topic index)
There are 6,029 posts in this topic. You are on page 12 of 121.
#551 3 years ago
Quoted from Chalkey:
semicolin you can get some really weird lamp behavior if anything from the coin door harness has grounded. Not sure if that might be what you have going on but maybe worth a look.
Thanks Chalkey. Isolated coin door harness and no change. Continued occasional misfires in the bonus and guardian lamp areas, possibly others if I stare at it longer.
#552 3 years ago
Quoted from Methos:
Is there a good source for these yet?
I have gotten a few lots of them on Ebay, just need to keep looking
#553 3 years ago
Quoted from Shapeshifter:
But not so good with wiring.
Shapeshifter, it is time you start learning some basic wiring. This is the same pop assy. you have in your Catacomb. You need to remove yours and see what is going on. Your switch contacts are that little black blob on the left. It attaches with two small straight slot screws. Remove the two screws and let the switch hang. The coil is not installed on this unit.
To remove the coil, remove the two screws at the bottom (not shown). This will allow you to remove the coil stop. With coil stop removed, the coil is going to fall off of its mounting position so look the coil over closely to see how it is setting before you remove it; You will want to reinstall it the way it came off. The coli sleeve is going come out with the coil; Pay double attention to how the coil sleeve is installed. You have been advised. You can let the coil hang or you can secure it with some tie wraps.
There will be two wires coming from the bottom of your pop assy. You have a wire splice mess going on in there. Don't cut any wires yet, but try to partially remove at least on pop so you can see what is going on. After you have a look and if you feel comfortable, cut your wiring as close to the splice as possible and remove the pop assy. Or don't cut anything. Just pull the pop from the play field and look around. There are only two lamp wires coming from each pop so there cannot be too much to look for.
You biggest challenge/headache is the lousy screws Stern used to put this pin together with. They are a shallow head bolt. They are not magnetic. They are a pain in the ass to reinstall; You will learn to miss Phillips head screws.
The good news is that your pops do not have to be lit for you to play your pin. I don't not have my Catacomb pops lit up and I have good times playing. Lit pops have just not been a priority for me at this time but I will get there.
If you run into problems, send me an email.
#554 3 years ago
Well got the games Saturday the Dracula is dead has an Alltek mpu with a solid on led I'm going to replace the rectifier board, the Stingray is somewhat living with a couple of coils out has anyone ever produced a repro of the often missing center seashell plastic?
#555 3 years ago
Quoted from cottonm4:
Thanks for this.
Will start investigating!
Have seen a wire is stuck under the pop bumper plastic frame so that is first change...
#556 3 years ago
And, just bought PavBall and I’s fourth classic stern. Joining our Quicksilver, Catacomb and Seawitch is (this photo was from HAAG a couple weeks ago, but this is our new game):
#557 3 years ago
Quoted from TigerLaw:
And, just bought pavball and I’s fourth classic stern. Joining our Quicksilver, Catacomb and Seawitch is (this photo was from HAAG a couple weeks ago, but this is our new game):
Looks grand ! Is it clear coated?
#558 3 years ago
Well my buddy bought a house and he'll be taking his Trident that I've been housekeeping for years pretty shortly. I figured it was time to snag another to fill the spot. Always happy to get one you don't see too often (though no official production numbers on IPDB).
Also as noted above with the strange harnesses, when I was unplugging the rectifier I saw the coin door harness is for a Lightning... It must have been total grab whatever works.
#559 3 years ago
Yes it is. I’m going to do some touch up work on the cabinet but it looks pretty great. Will post some photos when I pick it up.
#560 3 years ago
Has anyone purchased the Classic Arcades Dracula translite? My bg is fairly rough I know BG Resto has done it but this is a budget resto.
#561 3 years ago
Quoted from TomT:
Classic Arcades is less than budget, it will be shit. Search for all the disappointed customers on pinside. Don't be fooled!
#562 3 years ago
Quoted from eh97ac:
I've bought a few items from him over the years and they certainly do not belong in a "restored game".
However, everything has it's place. For a budget game you just want flipping, tournament game for a show, or a game on route, I believe they are fine.
#563 3 years ago
Quoted from eh97ac:
I've purchased from them a few times in the past I know the quality can be suspect.
#564 3 years ago
Quoted from statictrance:
Nice find! I married into a circus family, so I've been on the lookout for a Split Second machine around me. Keep us posted on your progress.
#565 3 years ago
Quoted from fissionch1ps:
Where are you located. It doesnt say.
#566 3 years ago
Quoted from Mitch:
I updated my settings. I’m in Florida.
#567 3 years ago
Looking for some drop target return springs, 5A-171. What's a good substitute? The DE/Sega/Stern current spring? https://www.pinballlife.com/data-eastsegastern-drop-target-spring.html
#568 3 years ago
Quoted from CaffeineSlug:
For which pin? Stern used two types of drop springs that I know of. One is long like the pic you showed and one is shorter.
#569 3 years ago
This would be for Meteor.
#570 3 years ago
This drop assembly is from a Big Game. There is a cross tube mounted that the springs attach to. The cross tube and short springs are used in Big Game, and all of the Sterns that came after.
The Meteor drop target assemblies I have do not use the crossover tube. Instead, the springs are the longer springs that attach to the lift blades down in the bottom of the assembly.
The pic you linked from Pinball Life is the correct longer spring.
#571 3 years ago
Anybody seriously interested (not casually curious) in a Boston area "Big Game" - PM me.
Playing correct B+ copy with an Alltek CPU.
$1,675
#572 3 years ago
A bit of troubleshooting help...
I bought brand new flipper mechs for my Dragonfist from Pinball Life. I installed the right side last night. I moved the wires over 1 by 1 from the old mech to the new mech. I realized quickly that the flipper was getting weaker. Lifted the playfield and found the coil was hot. Shut game off, let it cool a few minutes. Double checked the EOS switches and all my soldering connections, seemed okay. Tried playing again, this time each time I flipped the right side the lights in the game flickered and after about 4-5 flips the game just shut off completely. Now it won't do anything. No LED comes on at all with the MPU, nothing happens at all on the game at the moment.
Any ideas what just happened?
#573 3 years ago
Quoted from Tsskinne:
It does not matter what lugs you put the wires on, it matters what wires are connected to the proper diode sides (anode vs. cathode). Compare your old coil's diode orientation to the new coil's diodes. Not all are the same.
#574 3 years ago
Blown fuse? Did you have a flyback diode in place on the flipper solenoid?
#575 3 years ago
The coils can be installed in the brackets with the lugs pointing in either direction. Are the old and news coils installed in the same direction in the brackets? If not and you were not playing attention it would be possible to wire them up backwards.
This is a left hand side from a Meteor. THe blue/white power wire is on the left lug. The right hand side will be the same way except the green wire on the left will be an orange wire on the right hand side.
If you are holding the coil in the other direction then the blue/white power wire would on your right hand side instead of your left.
#576 3 years ago
Quoted from ejg10532626:
$1,675
Might you post some pics?
Just out of curiosity.
But 'ya know might help the sale.
#577 3 years ago
Can someone recomend a set of replacement legs for my Stern Lightning?
#578 3 years ago
Working on a stern seawitch. Was wondering if anyone is making the fuse sticker on the rectifier plate?
#579 3 years ago
Quoted from jkashani:
Pinball Resource.
http://pbresource.com/legs.html
Bally leg. part number: #LEG-28GR
Dark Grey non-ribbed.
#580 3 years ago
Quoted from Tallon:
http://www.pinballrebel.com/pinball/cards/
I just printed one out & glued it on
#581 3 years ago
Quoted from Tallon:
http://www.pinballrebel.com/pinball/cards/Stern/Stern_SS-series_MPU-200_fuse_label.zip
#582 3 years ago
So it was the furthest fuse to the right on the rectifier board, it tested okay but swapping it out made the game come back to life. My right flipper is still causing the lights to flicker, I only gave it 2 flips this time before shutting it off. I double checked my wiring from the original and its definitely correct. I tried swapping the EOS wires and no change. I replaced the diodes on the coil itself (the coil is brand new from Pinball Life), any other ideas?
#583 3 years ago
Does it work fine if you put the old parts back in?
#584 3 years ago
Quoted from chuckwurt:
Good question. I got a defective coil from PBR one time. Maybe the coil is defective.
#585 3 years ago
I'll give it a shot after school and see what happens.
#586 3 years ago
Thank You
Pinball Resource.
#587 3 years ago
You removed the fuse and it had continuity?
It reads like you’re having flyback. Test your solenoid and diodes thoroughly.
It’s possible you could have a something making contact near the flipper due to the slight jostling.
You could call pinball life too, they may have a tech that could walk you through their checks.
#588 3 years ago
Tsskinne did you make sure your EOS was properly gapped on the resting position as well as "flipper up" when fully assembled? I've seen people burn up a coil because they set the gap when wiring the eos switch but before installing the coil stop (stops the flipper sooner).
I'd make sure that the flipper assembly is still fully free moving. Starting to get weaker could be the coil / sleeve starting to deform due to heat. If the coil heated up that much it'll continue to cause fuse issues etc even if you resolve the root cause. You can check the resistance at the lugs vs youe working coil.
#589 3 years ago
tsskinne did you make sure your EOS was properly gapped on the resting position as well as "flipper up" when fully assembled? I've seen people burn up a coil because they set the gap when wiring the eos switch but before installing the coil stop (stops the flipper sooner).
Solid advice. It could be stuck in high voltage and is just toasting everything.
#590 3 years ago
Yeah I don't set the EOS until the flipper is installed, but good to double check it.
#591 3 years ago
What are you guys using as a replacement speaker in the early Sterns?
#592 3 years ago
Quoted from TomT:
You could try one of these:
https://pinside.com/pinball/forum/topic/new-6-inch-speakers-found
#593 3 years ago
Quoted from TomT:
amazon.com link »
#594 3 years ago
Quoted from eh97ac:
amazon.com link »
this is the one i used also
#595 3 years ago
Thanks guys I have one on order.
#596 3 years ago
Hey folks!
I’ve recently started building my own Orbitor 1. Thread here:
https://www.pinside.com/pinball/forum/topic/orbitor-1-a-scratch-build-reaching-for-the-stars
I’m glad there are new speakers I can use for the cabinet as I need ALL the hardware.
Are there any options for the transformer and other items? Also can anyone provide great pictures of the backbox for me?
#597 3 years ago
Does anyone have any nos stern drop targets or and used ones (any condition) they would sell. Dont care what game they are from.
Send me a pm.
#598 3 years ago
Setup both quicksilvers. One will be for sale soon.
Archived after 0 days
Sold for $ 5,000
Contributed to Pinside
Quicksilver (MN) Archived
Used - shows wear, needs some work “Selling a project Quicksilver. Currently non-functional. I assume anyone buying this rare game will restore it.”
2018-11-12
Wind Point, WI
5,000 (OBO)
#599 3 years ago
If you were making an apron for Quicksilver, which of these two machines is generally regarded as the correct color scheme?
#600 3 years ago
Quoted from Mitch:
Send me a pm.
I may have a few with different colored Stars.
