Archived ad
Pinside keeps a record of old ads in its Market Archive, for historical purposes and as a price reference. This ad has been ended by its seller and is now archived.
Other items - for sale
Premium Virtual Pinball Machine from Xtreme Gaming Cabinets
Added: 2023-04-24 13:58:58 UTC
• Re-listed: 2 times (July 17th, 2023)
• Ended: September 12th, 2023
Price
$ 11,900
Putting out some feelers about a VP Machine I have being built. I ordered it in March 2022 so it should be built very soon! Skip the wait times, which are more than a year now if you order!
Current Artwork selected is Ghostbusters(will attach picture), but if you work out a deal soon I can have them change it.
It's all been paid for $8900 minus shipping costs and customs estimated $2000 for that.
VP Machine = $6400
Titan Upgrade = $2400 (they don't offer this package anymore has the big daddy 144hz 4k 43" ASUS Monitor)
Pallet = $120
Total = $8920
Premium Upgrade(Parts List below), Titan PC Upgrade(PC Specs below), 144hz 4k Monitor Upgrade (ASUS), 1.7 Drive Upgrade
Description from Website:
Our XTREME PREMIUM PINBALL™ 43" 4K 144Hz Virtual Pinball Table does it all! This machine runs ALL pinball tables in ONE... truly AMAZING! We use the very best components to faithfully bring back the nostalgia of playing pinball, but this time without spending a fortune in coins! Relive all the pinball tables you love and adore in a single unit!
1350+ Pinball Tables Compatible (4K)
Real mechanical feedback, Stern shaker motor, 10 x solenoids, and a gear motor, plus 5 tactile feedback speakers and a 4.1 sound system (yep, 10 speakers!), makes the experience feel and sound like a mechanical machine.
Our premium model also comes with matrix lighting and addressable LEDS down both sides of playfield, undercab, on the topper, and around the speaker grilles.
Dimensions:
1300mm Length
800mm wide Backglass
1880mm Height
Note: Height can vary by around 20-25mm with adjustable feet. Beacons increase height by 100mm. Topper increases height by 300-400mm, although can be customized to match beacon height.
PC Specs (Titan Upgrade):
GeForce RTX 3080 10G
Ryzen 9 CPU
32 GB DDR4 3200Mhz RAM (2x16)
MSI B550M Motherboard
High quality 1000+ watt PSU
Heatsink/Fan
Parts List:
ASUS 43" 144Hz 4K UHD Gaming Monitor
LG 32" Full HD Monitor LCD backglass and 22" Full HD Monitor DMD and Topper Screen
Full-sized cabinet - Williams widebody dimensions
Mechanical Force Feedback Package (DOF enabled -10 x Solenoids)
Knocker Solenoid
Stern Shaker Motor
Gear Motor (reproduces crane noises on the playing field with adjustable Intensity Knob)
Williams/Bally Tilt Bob Mechanism Assembly
16 channel FTDI relay/controller + power supply for mechanical feedback devices
Matrix lighting playfield (Teensy + 2x144 / 8x32 + power supply) game-controlled
Undercab game-controlled LED Strips
Game-controlled LED Rings on backbox speaker grilles
2 x LED beacon lights activated in game
Custom designed topper with integrated, game-controlled LED Lighting
Z333 (or Z407) Logitech Speaker System with extra 2x 270W speakers
Tactile transducer speakers that interpret the mechanical sounds from the game as vibrations. 4 x Dayton drivers
Dayton Tactile Bass Shaker
Digital Nudging Support (allows you to bump the table and the ball will move accordingly. Slam Tilt enabled)
Plunger (and a large LAUNCH button underneath)
Laser cut side rails
Fire button and laser cut steel plate on lockdown bar.
Full-size double pinball coin door with lit buttons
Extra Ball button (on coin door)
Stern cup holder
Dual Flipper Buttons on each side (MagnaSave and other functions)
Flipper Buttons: High-Performance Arcade Pushbuttons with integral minature gold-plated leaf switches
Tempered Glass Playfield Shield
Anti-reflection board below DMD display
Powder Coated Metalwork - Steel Legs, Lockdown bar, and side rails
External USB ports (Front of machine)
Power On/Off Button (positioned on the front underside of the cabinet - power cord in the back)
Sound, lighting, and feedback controls at front of cabinet
Contact
Note! This is an archived ad. No longer for sale!
Seller insights
These are IronMan8Bit's market stats.
Listing result
The seller marked this ad as "not sold". The item did not sell through Pinside so there's no listing result.
