(Topic ID: 219538)
PPG Omni MC730 Playfield clearcoat question
By Dono
12 months ago
  • 5 posts
  • 2 Pinsiders participating
  • Latest reply 12 months ago by Dono
    #1 12 months ago
    Live in Maryland with strict restrictions on the types of clears allowed ... the only PPG option available for my paint shop is one called Omni MC730... it’s supposed to be a bit hotter than other Omni clears and a lot less solid content... anyone have any experience with this clearcoat product?
    #2 12 months ago
    No experience with that exact clear but tons of experience in general so what I can tell you is that “hotter” generally means faster and “less solids” means lower build.
    I prefer the opposite. Slower and higher build.
    Slower generally means less die back and less heat within the chemical reaction.
    Higher solids gives a better build and gloss retention as it cures.
    Both these qualities make for longer cure times as a result.
    #3 12 months ago
    Quoted from High_End_Pins:
    Makes total sense and helps, thanks for the input.. my guy also has a few products from Cromax (LE5100/LE5600) and a cheap option called Vietek 33-390, any experience with these? The Cromax is crazy expensive - $480 vs $165 for the Omni and $120 for the Vietek.
    #4 12 months ago
    Quoted from Dono:
    The Cromax LE5100 would be the best option of those because it is a two part clear so you save a little money there instead of the three parts needed for the 5600
    Also the 5100 is a slower dry time meaning it will flow out better and retain gloss best.
    Most “snap dry” or accelerator type product are made primarily for the auto body industry geared solely towards production and less significant uses like trimming out parts(painting the inside of them prior to install) and they don’t carry over as well into Pinball uses when compared to the more traditional slower products.
    #5 12 months ago
    Thanks so much for the much-needed info Ill go with the 5100.
    $ 14.99
    PinballElectronics.com
    $ 5,599.00
    Classic Game Rooms
    $ 7,499.00
    Little Shop Of Games
    $ 22.50
    $ 279.95
    $ 94.95
    CzTV Mods
    $ 59.00
    Sparky Pinball
    $ 142.00
    The MOD Couple
    $ 76.95
    $ 29.99
    $ 29.99
    Full Tilt Pinball LEDs
    $ 16.95
    $ 57.95
    PinBoss Mods
    $ 90.00
    Lighting - Under Cabinet
    Third Coast Pinball
    $ 199.99
    Cabinet - (Alt) Translites
    FlyLand Designs
    € 8.10
    Buthamburg
    Pinball Photos
    $ 5.00
    Doc's Pinball Shop
    $ 29.99
