(Topic ID: 223449)
PPB Board- I'm guessing this white powder shouldn't be here?
By jaybeedee
1 year ago
  • 16 posts
  • 11 Pinsiders participating
  • Latest reply 1 year ago by DanQverymuch
#1 1 year ago
I was getting started on disconnecting the connectors from the playfield so I could do flipper rebuilds and VUK tune-up, when I saw the white powder on the resistors on the PBB!
Is this just age, or does it suggest a different underlying problem ?
Is it important to replace them, and would any deterioration be likely to cause gameplay issues?
Thanks for any help.
John
#2 1 year ago
Looks like the cement is breaking down and dropping onto the resistors below. I've never seen that before. Usually they don't go bad.
#3 1 year ago
Those are cement resistors that are starting to crumble. You could have them easily replaced by Chris Hibler chrishibler.
#4 1 year ago
Quoted from Crash:
This can happen if machine spends time in a basement with high humidity.
-Mike
#6 1 year ago
Quoted from pintechev:
I'm probably just confident enough with a soldering iron to be dangerous! and have a go at replacing them myself. Presumably the cement resistor has some properties such that I need to replace like with like, rather than just looking at any resistor with equivalent resistance & wattage ?
How important to replace them quickly ? My quick maintenance of the flippers might have just turned into something bigger.
#7 1 year ago
I would vacuum off the mess and change them out within the next month before a real issue starts.
-Mike
#8 1 year ago
I’ve never seen that before. That material is part of the thermal design of the wire wound sand resistor.
Easy replacement.
Clip the leads close to the board.
Heat the leg from the solder side and gently extract it.
Clean up the hole in your favorite way.
Install new part leaving plenty of air gap between the part and the board.
Clip the left over leg =outside= of the solder meniscus (the solder volcano).
Have a beer and marvel at your handiwork.
Chris Hibler - CARGPB #31
http://ChrisHiblerPinball.com/contact/
#9 1 year ago
Quoted from altan:
It's snowing.
Better call Crockett and Tubbs.
#10 1 year ago
The devil's dandruff
#11 1 year ago
I've heard of cementmites. Never really saw the result of being infested with them, until now.
#12 1 year ago
Quoted from ChrisHibler:
Easy replacement.
Thanks Chris. How important is the resistance? I am about to order some replacements, and I see that on my board the resistors are 5ohm and most of the other images I see online, they are 3ohm.
The local supplier doesn't have 5ohm, but has lots of other specs - 2.7, 3.3 .... etc with 4.7ohm and 5.6ohm the closest to what is currently on the board.
Otherwise it is ordering from China
#13 1 year ago
Quoted from altan:
It's snowing.
Quoted from TheHueManatee:
#14 1 year ago
Quoted from altan:
It's snowing.
#15 1 year ago
Quoted from jaybeedee:
Yes...5 ohm are a bit scarce these days. I can't say why DE settled on that value, but 4.7ohm is a good replacement.
Those are current limiting resistors for the flash lamp side of the function.
#16 1 year ago
I know I'm no one to contradict CH, but if I were you I'd just vac the mess and not worry about it. Maybe check occasionally in case the deterioration accelerates.
They're for flashers, so low duty cycle. The ones that are snowing don't look like they've overheated. Worst case, resistor opens and flasher stops flashing.
If it ain't broke...
Still, it'd be an easy repair to get your feet wet with on board work, I suppose.
Briarcliff Manor, NY
New Hartford, CT
$ 279.95
Pin Stadium Pinball LEDs
Gweem's Mods
$ 21.00
$ 399.95
Rockford, IL
Greenville, NC
$ 50.00
