Powering a board on the bench can be a hassle if you don’t have an old PC/AT power supply to do it. But there’s an easy way for you to get the +5 and +12v necessary to power most boards – buy yourself a USB-SATA drive adapter.
You can pick up one from Amazon for under $10 here:
http://www.amazon.com/Drive-Adapter-Converter-Optical-External/dp/B001OORMVQ/ref=pd_cp_pc_2
The power brick included with it supplies +5v@ 2A and +12v @ 2A – more than enough to power a typical MPU board on the bench. The brick has a standard 4 pin drive power connector where you get the +5 and +12v and an LED to let you know you have power.
It comes with a power adapter cable that allows you to hook power up to a SATA drive. I took the one in the kit and modified it on one end with a 9 pin molex connector to create a dongle that can plug into the MPU board. I suspect I’ll create other dongles to power different boards on the bench as time goes on.
This one will work for many systems such as Williams 3-11. I also created loop wires to make it easy for me to tap the +5 and ground to power other devices, such as the great Siegecraft LED display!
The best part about this is that it is QUIET! No fan running from some old power supply. I had no problem running the Siegecraft solenoid tester (lower left corner – notice the LED on – that’s the flashlamps flashing in attract mode on FP,) lamp tester (bottom middle) and switch tester (middle right) in addition to the LED display. To power the lamp tester I used a drive “Y” cable and alligator leads to get the +12v needed to the bottom of the board.
I imagine this could also be used in a machine if you wanted to test an installed board and suspected you had a bad 5v line by disconnecting logic power and plugging this in. I may give that a try when I reinstall this board.
And when you’re done you can still use the brick to power your external hard disk!
Of course if you need other voltages like -5 or -12 v for testing this isn’t a solution. But for many it’s a cheap and easy way to get the voltages you need on the bench.
viperrwk
