(Topic ID: 264094)
Power supply tooth broken help!
By Jasenwm
  • 16 posts
  • 9 Pinsiders participating
  • Latest reply 4 years ago by Mrjamma
#1 4 years ago
So I just picked up a Mr & Mrs pacman pinball. It was in rough shape and needd a good cleaning. As I was reconnecting one of the connections on the power supply board one of the pins snapped off into the molex connector. The game turns on but the speech is muffled and it's playing weird. How do I 1. Fix the connection and 2. Get the stuck broken pin out of the connecter? In the picks the top pin is the one that broke.
20200314_184724 (resized).jpg20200314_184724 (resized).jpg20200314_184742 (resized).jpg20200314_184742 (resized).jpg
#2 4 years ago
Your going to have to replace the header to be sure you don’t have any other weak pins.
For the connector, all I can think of is to try and remove the female pin. At that point, there might be enough for you to grab hold of it and pull it out. Otherwise, you crimp on a new pin.
#3 4 years ago
Quoted from Billc479:
Agreed. You'll definitely need to replace the header on the circuit board. The connector may be salvageable, but you might as well replace it too. Will provide a more reliable connection.
#4 4 years ago
On the AS-2518-22 board pin J3-1 isn't used.
#5 4 years ago
Quoted from Inkochnito:
So he could just move the broken pin location and install new pin and move wires to it.
#6 4 years ago
I think what he is saying is there is not a wire in j3-1 so he does not need to do anything
#7 4 years ago
Quoted from ArnieC:
Bingo!
#8 4 years ago
Quoted from ArnieC:
I think what he is saying is there is not a wire in j3-1 so he does not need to do anythingso basically I can just leave it? That one pin doesn't make a difference?
#9 4 years ago
OP said game was playing weird and speech was muffled. I still stand by replacing the connectors.
#10 4 years ago
He should replace the capacitors on the S&T board.
Check the roms if they have tarnished legs and verify if they are still good.
The speech comes from those roms.
And yes, the pin is not used and does not need to be replaced.
However, you are now missing the pin which should center the key on pin 2.
Shifting one space up is possible and would have bad effects when you do.
Replacing the single pin in not nessesary, but very adviceable to prevent mistakes.
#11 4 years ago
I'm with this guy.
#12 4 years ago
YES! I think that is the problem. I ordered new capacitors so hopefully that will fix it.
#13 4 years ago
How do test the roms? With a Multi meter?
#14 4 years ago
So I figured out the board was being held in place by two metal screws. When the screws touched the metal on the front door it was making the sounds not work correctly. Once I mounted the board without the screws the sound was perfect and the game played correctly. I did order a capacitor kit for the sound board so I'll change them out anyway. Thanks for all the help guys!
#15 4 years ago
Nice catch.
Oh, and to answer your earlier question...there's not really any way to easily check ROMS. You'd have to have a chip reader/burner, and have it read out the data contents against a checksum to verify it's all still intact, or...what most people do, simply replace them and if it starts working, issue generally resolved. It's not a common issue in my experience. I've replaced ROMS due to failure on maybe 2 games out of the 60 I've been through.
#16 4 years ago
Quoted from Jasenwm:
No, not with a multimeter. You will need an Eprom programmer to use to verify the ROMs are good.
$ 119.95
Allteksystems
Third Coast Pinball
$ 18.95
$ 22.95
This page was printed from https://pinside.com/pinball/forum/topic/power-supply-tooth-broken-help- and we tried optimising it for printing. Some page elements may have been deliberately hidden.
