Newcomer here, 60 year-old jack-of-all-trades, master of none...
Picked up this Brunswick Alive cheap...it was working in a little country store and suddenly quit.
On the Board I found a resistor (half of one) lower right corner, beside 7815 regulator, and showed signs it had burnt. And no way to identify it...Recently I picked up a dud board from Steve at PR, and it had the resistor in place. I figured it to be 5.1 ohms at 5% with an online calculator. (Hmmm don’t know the wattage—guessing 1 watt maybe)...no time lately to try that out...
In the meantime, something had me digging into the overall game schematic (as we know none seem to exist for the board) and was curious about the supply transformer. Breakers are all loose and such—just done feel right. Anyhow, I took measurements of the outputs and it seemed it was bad, but I read from many posts that almost never happens. Couple more times it seems I’m getting some other readings. (Not very smart me doing the typical—one probe on the yellow Common lug, and the other probe on each output of 2.7v, 6v, and 27v lugs after I desoldered the unit away from everything else) I’m going to put it back in and try measuring at other points...
Question: What’s with the “-6v” lines and such I’m seeing in the schematic? Is it feasible to replace this unit with more traditional power supplies and get rid of the associated rectifiers?
I’ll attach schematic views...
Thanks for any guidance.
Tim
