Hi!
I recently bought a semi broken ms frankenstein with no experience in either pinball repairing or electronics (have not used a multi meter before).
After some time familiarizing myself with the game and manual I've concluded that all 32 volt mechanisms are dead. This includes flashers and 32v coils. Flippers and other 50v coils work in diagnostics.
I've measured the voltage on the power supply board as seen on the attached image.
Since my experience on reading schematics and electronics in general i would be super grateful for some help on if I've measuring the right thing and what the next step should be?
Another thing that might be worth mentioning is that if i go to the diagnostic mode for flasher cycling test. My working 50v coils is triggered.
As i understand it, this has to do with my PPB L/R relay is "stuck" on one side. The coil side. Is this because it runs on the same power source as the 32v stuff?
All fuses have been taken out and checked with DMM.
