On old Ballys - transformer in back box - there is a power lug choice. I just noticed it while troubleshooting another problem. Basically, if your input voltage is 115 v you use one set of lugs on the xformer. 120 v switch to another set of lugs. Well, turns out I measured 121 v incoming but it was on the 115 v lug. So, my question is, with this set up am I pushing too much voltage downstream? I assume I should switch to the 120v lug, any suggestions?
