New! Dark mode!
(Topic ID: 175807)
Powder coating a ball, thoughts?
By FunkyFreshWalrus
  • 27 posts
  • 16 Pinsiders participating
  • Latest reply 3 years ago by OLDPINGUY
    #1 3 years ago
    Just wondering if anyone tried powder coating a ball? Painting? Other coatings?
    #2 3 years ago
    This is a horrible idea, unless you like the idea of powdercoat leavings and and an uneven ball in your machine.
    #3 3 years ago
    Wouldn't be able to powdercoat it without a flat spot.
    #4 3 years ago
    Quoted from CrazyLevi:
    That's what I thought. I am wondering if anyone tried it, and how quickly it degraded. What about as a captive ball that doesn't get a lot of direct impact?
    What about other alternate balls? I know there is the ceramic ball from TZ, and people sell a few with some designs heat treated into them. What about a brass ball, or a durable polished stone.
    Something like this:
    ebay.com link » Malachite Natural Sphere 27 Mm Sc13 6 Dr Congo
    #5 3 years ago
    I've seen some "colored" balls at pinball life and other vendors.
    I'd never put one of these in a game of mine. Pinballs are not the place to get cute.
    #6 3 years ago
    Quoted from Coyote:
    Couldn't you tumble/polish it smooth?
    #7 3 years ago
    I'm waiting for the first semi-transparent color changing LED pinball to be the next big thing. The I'll believe we have done it all.
    #8 3 years ago
    Quoted from FunkyFreshWalrus:
    If you want to know the damage that a non-spherical pinball can do to your game, check Gottlieb System 3 games from the 90s. Gottlieb decided to save about 4 cents per pinball buying defective, unfinished ball bearings. These "soft" balls ended up DESTROYING the paint between the flippers and below the mylar on tons of these games.
    Thankfully, nobody really cared because these games sucked anyway, but still...not a good idea to even entertain taking a chance like this on your pinball machine.
    #9 3 years ago
    It's not that. You just couldn't physically powdercoat the entire ball. It needs to sit somewhere as you can't hang it to powder coat.
    #10 3 years ago
    can't be done or will never be perfect. i could go with brass just for fun but that's about it.
    #11 3 years ago
    Quoted from SUPERBEE:
    Float it above a couple well placed magnets?
    #12 3 years ago
    Quoted from Mbecker:
    The only problem is the magnets...how do they work?
    #13 3 years ago
    I'll let you know as soon as I figure out these damn tides.
    #14 3 years ago
    2015's open house really was pretty crazy.
    #15 3 years ago
    Quoted from Blackjacker:
    I'm sorry...I meant balls of color.
    #16 3 years ago
    This has to be in the running as one of the stupidest things ever on this site, and that's saying a lot.
    #17 3 years ago
    Just throw some jawbreakers in there and be done with it.
    #18 3 years ago
    Quoted from volcanodiver:
    I never said it was a good idea. Just wondering if anyone has tried it.
    It would be done as a gimmick in a beater parts game if anything. I know there is the TZ ceramic ball, and the Viper Night Driving balls. The viper balls are coated steel balls. So there must be some way to get a round coating on a ball.
    #19 3 years ago
    VND is a plastic coated ball, injection molded. terrible balls, they get out of round immediately. the current plastic coated balls do the same thing. the only good thing about these coated balls is the plastics are soft so they don't chip and grind the PF.The ceramic ball in TZ is created round not coated over steel.
    #20 3 years ago
    What I've been wondering is if anyone's ever tried putting super balls in a pinball machine... I would imagine that the friction could do quite a bit of damage, but I'm still surprised I've never seen anyoney try it.
    #21 3 years ago
    Quoted from mystman12:
    Tried it for laughs. It was too light to work. I could launch it, if it managed to make it out into the shooter lane. But the first roll over it hit would just stop it.
    That's what led me down this road. The game I was playing around with is a players Tri-Zone that is worn down to wood so bad its really not ever being salvaged.
    #22 3 years ago
    I don't know how easy this would be to do with a pinball, due to the weight, but in our Mechanical / Process Engineering lab way back when we used to spray conformal coating on ping-pong balls by floating them in a stream of air. This causes the ball to spin in mid air and the conformal coating, which was very thin, was sprayed on with a airbrush. Why were we doing this? I don't remember the initial reason but man did it add to the complexity of our ping-pong matches (we had a table in the break room), not only could you put a lot more spin on the ball but when you did and it hit the table it would REALLY take off in some fun ways. Clearly this project was not sponsored by management.
    #23 3 years ago
    When everyone is absolutely appalled at how horrible your idea is, you know you might be on to something!
    I've been powder coating pinball parts and all kinds of other things for a while, and I'm pretty sure I could powder coat a pinball. I'm also pretty sure I could get it as close to round as any other non-coated pinball. Powder coating does a great job of laying down a very consistent thickness. All that said, I'm not confident in how long the final coating would last. I'm thinking it would work best on early solid state games that are inherently less violent. Your captive ball idea would work even better but obviously be limited in how visible it is.
    If we suspend disbelief in the concept of being able to powder coat a pinball. What games/colors would be the best to change? I just finished shopping a Globetrotters and I'm thinking a "basketball orange" colored pinball would look pretty cool with the theme.
    -Jay
    #24 3 years ago
    Quoted from jrobinso99:
    Yes, that would be awesome for any basketball themed game.
    Multiple colored balls in multiball would look really cool.
    What about anodized aluminium balls? They would be much lighter than steel, but how would they compare in weight to the TZ ceramic ball?
    #25 3 years ago
    Aluminum would be horrible. Too soft and would dent the first time it hit something harder.
    #26 3 years ago
    Im thinking about powdercoating my balls.... do you think it will hurt ? Do i need to shave first in order for the powder to stick ? ...
    #27 3 years ago
    Not quite...But I did make post sleeves out of cores drilled from a super ball!
    Big improvement!
    Ive spent many hours and letters since 1968 to Wham-o to make Rubbers out of Super Ball Material...no luck...even Matt was looking into....
    $ 99.99
    $ 71.99
    Lee's Parts
    $ 48.00
    $ 139.00
    Sparky Pinball
    $ 19.95
    $ 159.00
    $ 12.00
    $ 9.95
    $ 9.99
    Bent Mods
    $ 69.99
    $ 40.00
    Metalhead Pinball
    $ 24.25
    The MOD Couple
    $ 159.99
    $ 40.00
    Arcade Arts
    $ 58.00
    Chrome Candy
    € 25.00
    YOYOKOPTER MODS
    $ 99.00
    Loop Combo Pinball
    Various Novelties
    GC Pinball
    $ 48.00
    $ 48.00
    $ 19.99
    Back Alley Creations
    $ 24.00
    Pin Monk
    $ 69.99
    $ 18.99
