OK, working on a POTC.
Ship motor is dead. Will not operate in test.
Up/Down limit switches test OK
Sails up/down coil OK
Sails lock latch OK
Called Chas at Stern; Manually moved the ship into the midway position so it does not matter which way it moves and tested the motor directly with a 9v battery first and then the 20v supply from a nearby flasher, and it will not move at all.
The gearbox does not seem jammed since I can move it fairly easily by hand.
Can this be repaired by me or someone else?
A replacement motor/gearbox assy (511-5024-00) is 200.00. Ouch.
RussMyers
