I just got a PotC, when picking it up the trough VUK & tortuga VUK weren't firing, but the game has less than 200 plays on it, so I figured it was a fuse/something came loose. After getting it home, the bottom flippers and right sling weren't firing either. I opened up the back box and tested all the fuses, which all appeared to be good. I then turned it on and saw that F701's light is out, as well as 704, 705 and 706, which are all under 701. I swapped 701 with 702, since both are the same 10A fuses, but the light is still out on them. All of the items that are not working are under either 704, 705 and 706. I'm not sure where to go from here though, looking at the fuse stream page (D-91), above that is transformer. I don't *think* that is the issue because all the other fuses (702, 703 & 714) are all lit up, and those items under them seem to be working.
Any ideas where to go from here? I haven't even gotten to play it yet, and I'm starting to get twitchy.
