Quoted from dphelps:What do I do to correct it, just reseat the opto connector?
Try reseating the connector. If that doesn't solve the problem, you should reflow the solder.
I was playing Klingon Multiball today, and I shot the Vengeance which was lit for a jackpot. The ball just went in and came right back out. Isn't the drop target supposed to grab it?
Quoted from Aurich:I think someone said Iron Man VE has an improved connector? It's an annoying issue for sure.
So does my Star Trek, manufactured in June. They must have started putting them in recently.
Quoted from Nokoro:So does my Star Trek, manufactured in June. They must have started putting them in recently.
Can you take a picture. I'd like to see what they changed and if I have it.
I just found another bug. During victory laps, I hit enough warp ramps to light the extra ball. When I shot the ball up the middle, the ball bounced in and out of the lane without the extra ball being collected. I tried this several times, and each time I got the same result. I was not able to collect the extra ball until victory laps ended.
Quoted from gweempose:I was playing Klingon Multiball today, and I shot the Vengeance which was lit for a jackpot. The ball just went in and came right back out. Isn't the drop target supposed to grab it?
There Are problems with the Optos seeing the ball at times and what you are describing and other strange things are
Going on with the vengeance I have seen this and also when an extra ball is lit and it is also causing the ball to stick together for vengeance mb
After getting multiple tilt warnings trying to save an errant ball, the new tilt warning speeches cut across each other with the second one starting before the first one has even finished speaking.
Don't know for sure if this is new to the 1.5 code, but I haven't noticed it before.
Quoted from steve1515:Can you take a picture. I'd like to see what they changed and if I have it.
Here, check this thread out:
https://pinside.com/pinball/forum/topic/stern-has-addressed-the-trough-opto-connector-issue
I had company over and wasn't on the table when it started but a player pointed out my STLE started kicking out 2 balls and also started auto launching all balls for all players. I then played a single player game and it continued to auto launch but wasn't feeding 2 balls. I reset the game and it went back to normal. Sorry I cant give more details but will watch for a repeat.
Not a software bug but it bugs the sh!t out of me. I have now had 3 bad led boards. Stern replaced one that was the 3 bank stand up on the right. 2 others have had a bad solder on the led chip so the red got flakey and were intermittent or out. Both board were the ones under the outside loop insert. I called Stern who helped me track it down but would replace them because its past 90 days. I find it hard to believe this is an isolated case. Honestly this is my LAST Stern.
Quoted from msj2222:I had company over and wasn't on the table when it started but a player pointed out my STLE started kicking out 2 balls and also started auto launching all balls for all players. I then played a single player game and it continued to auto launch but wasn't feeding 2 balls. I reset the game and it went back to normal. Sorry I cant give more details but will watch for a repeat.
Reseat the two connectors to the ball trough with the power off. With practically every game having shakers (and I think the upgraded slingers too?), game shakes and connector comes loose. It doesn't happen often but it does happen. Now you know the fix, and it'll be a 45 sec fix for any of your sterns in the future. My acdc standup targets did this too (3 times) in the 1 1/2 years owning it.
EDIT: oh and it's good to know stern finally addressed this issue so we'll see a lot less of this problem moving forward.
Quoted from Eskaybee:Reseat the two connectors to the ball trough with the power off. With practically every game having shakers (and I think the upgraded slingers too?), game shakes and connector comes loose. It doesn't happen often but it does happen. Now you know the fix, and it'll be a 45 sec fix for any of your sterns in the future. My acdc standup targets did this too (3 times) in the 1 1/2 years owning it.
Thanks, after reading/following this thread is was going to try this. My AC/DC has had flakey drop targets since day 1. The N in TNT drops and now a couple in the AC/DC drops along with a couple bad LED boards out of the box. Just a bit frustrating. I cant see these lasting like my B/Ws
Quoted from Eskaybee:Ask and you shall receive:
we will come up with a family version. It may be included in the next release, but basic operation code needs to be fixed first. Thanks.
Awesome!
Loving the new code on my LE. Such a great update!!!
I have a strange problem with the LED under the Space Jump mission. In single lamp test it shows the White/Blue/Green/Red test correctly but in game it stays green when Space Jump mission is active. It should be Yellow, the color for Space Jump. Also when the game is finished it shows a wrong color when the light shows goes on.
I already send an email to the reseller for a new LED board but was wondering if it's not a software issue ?
Quoted from KLR2014:I have a strange problem with the LED under the Space Jump mission. In single lamp test it shows the White/Blue/Green/Red test correctly but in game it stays green when Space Jump mission is active. It should be Yellow, the color for Space Jump. Also when the game is finished it shows a wrong color when the light shows goes on.
It seems there is an issue with the red going out in the leds. That might account for it. Good luck
Another (very) minor bug: When completing all three levels of a mission, the DMD says '3 columns completed', while the call out says 'three in a row'. ...row vs column. ...too picky?
Quoted from SunKing:Another (very) minor bug: When completing all three levels of a mission, the DMD says '3 columns completed', while the call out says 'three in a row'. ...row vs column. ...too picky?
Does it say "3 columns completed" or simply "column completed?" Should be the latter, but I didn't pay attention to the dots. I'm fine with the call out remaining "three in a row."
Quoted from Snailman:Does it say "3 columns completed" or simply "column completed?"
Gosh, I think you're right. 'Column completed' ....my bad. And yeah, it's pretty nick-picky, I admit that. I guess I'm just not that good at finding bugs.
Quoted from Snailman:Oh yeah. It's been increased. Got it today, and was pleased with the pay-off. Definitely Picard it for your 2x value.
My biggest gripe is still that the 2x shot value from finishing a Level 3 Mission doesn't work correctly -- with or without a combo 2x in play.
Today, after DTD Level 3 finished, on the next ball, I shot a warp ramp straight up (no combo, no mode or anything else running) and it only scored 250K for the first shot.
Well, I guess I should read the code revision note from Steve Ritchie more thoroughly.... it says: <<“Drilling Down” a Mission through Tiers I, II, and III now awards “3 in a row” with new dots, and, the appropriate shot awards Double Score for the remainder of the game in all Missions and Wizard Modes. >>
To highlight the important part I missed: " ... all Missions and Wizard Modes." Not Super modes, warp ramp scoring (250K, 500K, 1M, 1M), or multiball scoring. Just Missions and Wizard Modes.
I don't know if I agree with that constraint, but can anyone confirm that the Mission shot and Wizard Mode shot values are indeed doubled for remainder of game??
Quoted from Rarehero:Here's a possible bug I noticed...I think it's just a text bug, though. During Nero 2, when you kill all 3 Romulans before another jumps in, it says " Bonus Jackpot 0". I think if they just remove that "0", we'd be OK.
I just saw this "bonus jackpot 0" tonight. I was playing Nero 2 and Vengeance became lit. When this happens, the Vengeance mode seems to clobber everything by putting "shoot the vengeance" on the screen, playing the vengeance ready music and I'm not sure it shows anything else. I could not tell where the nero 2 mode was so I shot the spinner, saw the bonus jackpot 0 message and promptly drained. I think there should maybe be a callout saying shoot the vengeance, but if you are in a mission it should not be changing that music or display animations until the mission is over. It's like the game is saying 'ok forget whatever you were doing, the vengeance is ready so shoot that'.
Also with Nero 2, I don't understand why the shots change around like they do. I complete right side shots and they stay off for a while, but then they come back on. Does this add back to the shots needed to complete or what? Maybe this happens in other missions.. I need to play it more.
If there are names for the combos, there needs to be callouts for that otherwise the player is just going to miss them.
Playing some more tonight:
The 'shoot the vengeance' display is way unnecessarily intrusive.
The display font for the end of ball bonus multiplier count is too thin (wrong font?) compared to everything else.
Shooting away team with one shot left does.... nothing??
Away Team start new mission. Not doing anything makes the mission auto select after about 10-15 seconds and start counting down the timer with the ball still in the shooter lane. It does not auto launch.
Lit shots changing around (seemingly) random on missions. Makes no sense and kills the need for strategy. Perhaps there are unique rules for these shots?
Many callouts can be completely drowned out by sound effects. Nero 'hello christopher, I'm nero' is a great example.
Jet bumpers stating 'level #' complete. Ok good, tell me what the next level does at the same time please. Lots of room on the dmd for that extra info.
Rob
400,000 starting points and only 5 thousand point increments on Galactic Lane shots?! The increments on the regular prime directive shots are WAY better (even though starting value is 100,000) and you can also combo the values for much higher points. Galactic Lanes needs to be worth more and have higher increments.
I have not played much of the other galactic modes, but since you are losing the ability to combo shots, the points better be darn well worth it or what's the point of going for it?
Rob
Quoted from Rob_G:I have not played much of the other galactic modes, but since you are losing the ability to combo shots, the points better be darn well worth it or what's the point of going for it?
You raise a good point about the points ...
I haven't read through the thread but the TILT warnings get lost in the callout queue and you have no idea where you are. Heck, I don't even know what it's suppose to sound like. A klingon swearing at you?
Quoted from Aurich:Twice in one game I had locks lit, and hit the ball up cleanly into the Vengeance shot, and the ball went up in, and rolled back out, with no response. On my third try the drop popped up and I got the lock. Maybe it's the code that keeps the drop from shooting up too fast (that used to happen to me, would go up so quick it would launch the ball into the air instead of letting it pass).
This happened to me three times in a row on Galactic Vengeance. Old code was perfect catching Vengeance shots. Grrrrr.
I'm thinking the away team shot should either turn off for 'one shot remaining' on level one missions or restart the timer in order to play the galactic mode.
Rob
Quoted from Rob_G:400,000 starting points and only 5 thousand point increments on Galactic Lane shots?! The increments on the regular prime directive shots are WAY better (even though starting value is 100,000) and you can also combo the values for much higher points. Galactic Lanes needs to be worth more and have higher increments.
Rob
I do agree some of the galactic mode points need to be tweaked into the positive. But I have had galactic lanes up to 750k and there's another use for galactic lanes whereas loop shots set up warp shots while using the lanes to increase points value. So I typically go for PD and galactic lanes early so I can get to warp 8 or so quickly and setup a double scoring attempt on my next mode/mb
Quoted from Rob_G:I'm thinking the away team shot should either turn off for 'one shot remaining' on level one missions or restart the timer in order to play the galactic mode.
Rob
I would like to see this as a 3 second grace period after time runs out. After that, void galactic mode. It would be nice to see prime directive 2&3 tweaked to add time on successful shots. Nothing worse than being punished for doing good and having to repeat modes over and over.
This happened to me tonight, but under different circumstances. I shot the vengeance to lock a ball, but it didn't lock and fell back down like nothing happened.
Rob
Quoted from Eskaybee:I would like to see this as a 3 second grace period after time runs out. After that, void galactic mode. It would be nice to see prime directive 2&3 tweaked to add time on successful shots. Nothing worse than being punished for doing good and having to repeat modes over and over.
I'll post additional thoughts as I play my game more. I have only had it a few days (built june 2014) and bought NIB. I really hope the bugs get cleaned up and we see a few more additions to gameplay, but without a 6 month wait.
Rob
Rob
I'd suggest posts on Galactic modes/scoring use the separate thread on Galactic modes. The level of scoring isn't really a bug.
Quoted from Snailman:I'd suggest posts on Galactic modes/scoring use the separate thread on Galactic modes. The level of scoring isn't really a bug.
No, but the measly 5000 increment might be....
Rob
Quoted from Rob_G:No, but the measly 5000 increment might be....
Rob
True. And by the way, I agree with your assessment of Galactic mode scoring -- outside of DTD and KB.
Quoted from SunKing:During Kobayashi Maru MB, the kickback arrow does not light.
I think that's intentional. Think of it like the kobayashi Maru, a test designed for you to fail. So not knowing if you have a kickback or not makes the pressure build up more as you progress through the mode. I like it.
Quoted from Eskaybee:I think that's intentional. Think of it like the kobayashi Maru, a test designed for you to fail. So not knowing if you have a kickback or not makes the pressure build up more as you progress through the mode. I like it.
It seems like you shouldn't even be allowed to finish Kobayashi Maru without rewriting the code yourself. After all, that's what Kirk did.
Playing a game just now and had multiball going with Prime 1. The balls drained except for one when I shot away team. The timer might have just been expiring or expired and it said 'Galactic Lanes Lit', except they were not lit and the mission ended instead.
Rob
Quoted from Rob_G:Playing a game just now and had multiball going with Prime 1. The balls drained except for one when I shot away team. The timer might have just been expiring or expired and it said 'Galactic Lanes Lit', except they were not lit and the mission ended instead.
Rob
I've seen this too and been meanin to post here. If you hit away team just as time expires, it'll award with the galactic lanes call out but will not start it just as you mentioned.
Found another bug...
If the ball saver is on and you lose the ball. A new ball is put into the shooter lane and auto plunged. If the ball isn't properly kicked out of the trough (i.e. doesn't make it into the shooter lane) the auto plunger still fires. Eventually a ball is kicked out again and auto plunged.
I believe that the auto plunger shouldn't go off unless the shooter lane switch is closed.
Quoted from steve1515:Found another bug...
There's a lot of bugs in the base code of Stern games in regards to ball save/search/launch. What you describe may happen in other games too.
Rob
I played tonight and during Klingon multiball, 2 balls got stuck in the left outlane because the lane wire had popped out and was blocking the path. So I pulled the glass off and put the balls in the shooter lane with the coin door open. The game doesn't realize the coin door is open (high voltage off) and keeps trying to launch the balls, making the launch sound repeatedly in the process. So to stop that annoyance while I fix the lane wire, I put the game in the root of the test mode. After fixing the lane, putting the glass back on, taking the game out of test and closing the coin door, the autolaunch does not work any more for the rest of the game.
I will also concur with what other people are saying that the drain callouts should not be the same as the end of mission callout. That just doesn't make any sense at all and becomes repetetive. Furthermore, on Tier 3 missions that you can fail, you still get the end of mission callout even when you fail the objective. This is misleading because it may make you think you beat the mission when in fact you haven't.
I don't understand why some Tier 3 missions are timed and others are not. There is a great disparity in the difficulty of these. Plus we've seen enough of the timer on the tier 1 missions, there needs to be something other to challenge us other than more time based missions. Like require so many combos for example, roaming shots, shoot black hole to light next shot, light ramp shots for each red matter target hit etc.
Rob
I'm still having two problems, one consistent and one not:
1. Consistently the Vengeance drop target when hit once, will register 3 to 5 hits in quick succession. VERY bothersome.
2. Inconsistently, when I push start, the game will automatically select a mission. Most always it's Destroy the Drill. You cannot change the mission, but you do have to launch the ball. This happens once in about every 30 games.
Murphy
Quoted from MurphyPeoples:I'm still having two problems, one consistent and one not:
1. Consistently the Vengeance drop target when hit once, will register 3 to 5 hits in quick succession. VERY bothersome.2. Inconsistently, when I push start, the game will automatically select a mission. Most always it's Destroy the Drill. You cannot change the mission, but you do have to launch the ball. This happens once in about every 30 games.
Murphy
I had this same problem in the old code. This one is a hardware problem. You need a new opto board at the entrance of the vengeance. If you go into switch test and bang on the playfield or tap the opto with a plastic stick, you'll see that it will trip the switch. If you call Stern, they will send you a replacement under warranty.
Murphy
Try adding washers to the drop target assembly like others have had to do on ACDC, and Star Trek. I had the same problem as you describe, and the washers solved the problem.
Murphy
I believe this is caused by the punch it button switch being triggered from the vibration of the ball trough. Adjust the switch so it's not so sensitive. If memory serves right, I barely had to adjust/ touch my punch it switch and it fixed this issue.
Finished super ramps tonight - which is totally awesome by the way. The last shot doesn't show the flyby animation or what points were scored, but just says "Super Ramps Completed" with little fanfare...
Rob
Sorry if this was covered or not a bug. I just finished all level 1 missions and Kobayashi Maru and on the second levels after I completed objectives, then locked to change missions they weren't registering as completed. If I chose them again it still said "destroy the drill 2" for example.
Quoted from Rob_G:The game doesn't realize the coin door is open (high voltage off) and keeps trying to launch the balls, making the launch sound repeatedly in the process. So to stop that annoyance while I fix the lane wire, I put the game in the root of the test mode. After fixing the lane, putting the glass back on, taking the game out of test and closing the coin door, the autolaunch does not work any more for the rest of the game.
I noticed last night that after I opened the coin door it didn't play the coin door chime sound, and after I'd had it open for a bit the game just did the drained ball sounds/animation. Might be a bug about the coin door switch? Or maybe you have to turn the coin door ball saver on?
This page was printed from https://pinside.com/pinball/forum/topic/post-st-15-code-bugs-here/page/4 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
