(Topic ID: 166606)
Possible power surge on my Flash Gordon
By aKa
  • 20 posts
  • 3 Pinsiders participating
  • Latest reply 4 years ago by aKa
#1 4 years ago
I have an old electrical setup at home, and I believe my Flash Gordon suffered from a power surge yesterday. Anyways, it doesn't light up anymore, apart from a faint light on the edge of the displays.
An electrician will come tomorrow to update my electrical setup, but I doubt he'll check the pinball. I read somewhere that a varistor and an associated fuse protect the rest of the machine from such a misadventure, but I can't locate the fuse next to the varistor (which looks fine, but I didn't test it).
Where and what should I look for to begin with ? Bear in mind that I'm quite challenged when it comes to the electric side of things, which is why I bought a perfectly working machine, that I just happened to finish restoring yesterday.
#2 4 years ago
The fuse is behind the rectifier board on the floor of the main cabinet. Look for a metal bracket that holds a square connector and the fuse is right next to it with a black cover. Also check to see if the line filter is blown.
#3 4 years ago
If you've got the faint glow, your game still has high voltage power.
Open the backbox, turn on the game while watching the LED on the MPU board (large upper left board).
Seven flashes?
#5 4 years ago
Quoted from Lovef2k:
I checked that fuse, and with my multimeter on 20k ohms (Am I doing this wrong again ?), it reads 0.06.
As for the line filter, if by blown you mean the case cracked open, then no, it doesn't look blown.
Quoted from vid1900:
Seven flashes?
Well, the machine lit briefly before fading away yesterday after the incident in my main electrical box in my kitchen, and on subsequent powering up, there was this faint light on the displays. Today it's definitely dead, no faint lights or blinking. Could it just have been some residual power still left in the machine ?
#6 4 years ago
Quoted from aKa:
No residual power.
Put your meter on OHMs, remove the fuse from the holder, and see what it reads.
#7 4 years ago
All right, I'm even more challenged than what I was suggesting in my first post.
Of course the machine is dead when you don't put the fuse back on ...
Things have mysteriously improved. The machine works, except for the sounds and voices (well there is that two tone sound during attract mode, but that's it), and the GI (except strangely the four lights behind Ming's head that light up when you start a game). The rest seems fine.
#8 4 years ago
The GI has it's own fuse on the rectifier board in the bottom. Remove and test with meter.
#9 4 years ago
Yes, F5 (20amps) is dead. I guess it's this one.
Now we're left with the sound issue.
#10 4 years ago
Well, I replaced the F5 fuse (it's a 20 amps fast-blow, right ?), and it blew again. I didn't even put bulbs in the backbox so there should be some room, power wise.
It worked well until that electrical issue in my apartment, caused by my toaster plug being shorted (we figured it out with the electrician), but a power surge should have blown the first fuse after the plug in the pinball.
I'm not sure what to try now.
#11 4 years ago
It's possible that you have a short in the GI circuit. It could have happened when you lifted the playfield. Unplug J1 from the rectifier board(board on bottom of main cabinet). The GI wiring comes from there to the playfield. If the GI fuse does not blow, then you know the short is somewhere on the playfield. Look for any metal touching the sockets or socket wiring. If it still blows, then look in the backbox. Also you have 3 GI lamps on the coin door that could short to the door which is grounded. It's also possible the your BR1 is blown on the rectifier board.
It's possible that a surge may have taken out your sound board. Be sure that the volume is turned up on the coin door, also play around with the volume pots on the board, they are known to be flaky from age and dirt. Also make sure coin door self test position 18 is set to number 3 which gives maximum sound option. Sound board test values can be found on pinwiki.com under attract mode test values. Early FG came with sounds plus and vocalizer boards that were later replaced with the squawk and talk board.
#12 4 years ago
If I disconnect J1, the fuse holds up, and even the sound works again.
I guess there's a short somewhere below the playfield, and I also guess it'll be a long hunt.
I noticed though that one of the sockets just next to the left flipper mount plate seems to be touching the plate. The socket is quite loose but its wire is desoldered (I didn't take the time to tackle this yet). Could it be it ?
I'm down to 2 fuses left, that I have to go across town to get, and I know that I'll have to buy a circuit breaker. Oddly enough, since I live in a big city (Paris), I've had the hardest time finding a 1 amp one for my other pinball when I needed it, and I had to order it from Germany. Maybe I'm not looking for the right thing ...
#13 4 years ago
Would a 16 amps circuit breaker do the trick in place of the fast-blow 20 amps fuse ?
Like this one : http://www.stquentin-radio.com/index.php?page=info_produit&info=10123&color=9&id=0&act=0
Or one like this that is supposed to go inside a fuse panel : http://www.castorama.fr/store/Disjoncteur-Phase--neutre-16-A-LEGRAND-PRDm824439.html?navCount=0
#14 4 years ago
It should, just don't get anything more than 20 amps.
#15 4 years ago
I remember vid1900 recommending a lower amp value for the circuit breaker than the actual fuse, and a 16 amps breaker like the one on the second link of my previous post can be found at every street corner, so I'll go with that one, unless someone believes a 20 amps breaker is more suited.
#16 4 years ago
So I bought one that you normaly put in a fuse panel (like in the second link of post #13), but of course it is made for two wires (phase and neutral). How do I handle it and not fry my pinball ?
#17 4 years ago
Normally, most people do it like this, using a blown fuse.
You may have to use alligator clips.
#18 4 years ago
Thanks vid, but that's not what I meant. I intend to use alligator clips, but my issue is that my circuit breaker is intended to be used in an AC circuit, with to wires in, two wires out (phase and neutral). I believe that for my needs, AC or DC doesn't matter, but I suck at understanding electrical circuits so I'm not sure where to plug the clips (I would tend to believe in and out of the phase slots).
#19 4 years ago
You might have to post a picture.
#20 4 years ago
It's the one on the second link of post #13.
$ 279.95
Pin Stadium Pinball Mods
$ 9.00
$ 90.00
