Hiyas!
Your problem isn't related to grounding your power outlet (that's a good idea, but it doesn't cause this).
For some reason your computer isn't coming on.
The most likely cause of this is unfortunately battery acid damage on the main computer board.
It could be a fuse!
So, inside your front coin door, on a little hook there is likely a different key. This key opens the lock in the backglass area.
If you look at the backbox, there is the dot matrix display, then above that is the backglass, in the center facing downward in the top of the wood framed backbox is the lock for the backglass.
Insert the key, turn it. Then run your fingers down the glass until you find the 'lift rail' plastic. Get your fingers under this little 'lip' of plastic, lift upward (less than an inch), and the bottom of the glass should clear it's track. Then pull the bottom toward you an inch or so, and lower the glass out of the top track. Set the backglass to the side.
Inside are three boards, a small one in the upper left, and two big ones on the right. In the upper right corner are some flashlight batteries. We are looking for evidence of battery acid, or corrosion. Let us know what you find.
Best answer is no battery acid problems!
On the bottom big board, there are lots of fuses.
With the power on and the front door closed, all four of the LED's in the middle should be on. Let us know if you don't have one of those LEDs on.
A lot of times this is a fuse issue, so if we know which LED isn't coming on, we can help figure out which fuse.
This could be a lot of things, so if you suspect something, take a hires picture of what you see and post it here.
Get back with us and I'm sure we can help you!
