Quoted from wayout440:Congratulations! I think you got a nice machine at a fair price. My advice is before you start on the cosmetic work, assess the electronics health thoroughly.
Get a DMM.
Read thoroughly the repair docs online (especially section
Before turning on the game for the first time)
techniek.flipperwinkel.nl/wms11/index1.html
techniek.flipperwinkel.nl/wms11/index2.htm
techniek.flipperwinkel.nl/wms11/index3.htm
Have fun, kill Yagov!
I own a few DMMs being an auto tech I'm also fairly capable of soldering wire. But hopefully I don't have to use them too much here! On startup there is some kind of switch adjustment message but once I get it in my place I will start a new forum topic in the appropriate section asking for advice, I will bookmark those links though.
Quoted from Nevus:Congratulations. You got a working f-14 for $900 bucks. That's plenty good. Now you can have a blast. If you want to enjoy it, just wipe it down and play it for a few days. Get to know the little issues. Then you can tear it down and really clean a it up nice!
Treat your self to about $25 bucks worth of handy items. Some Novus 2, new pinballs, replace burned out lights with cheap incandescents (with the power off!) and a cheap screwdriver that reverses with the built in 1/4 socket.
Have fun!
What is Novus 2? New pinballs will happen once I get the playfield cleaned up. As far as I can tell all of the lights are working right now. And I have a lot of tools!
I will end up putting LEDs in this thing at some point. I also found this protector instead of using mylar: www.pinballnews.com/learn/playfieldprotector/index.html
Uses no adhesive and stays in place because it is precision fitted, can be easily removed and wont stick to playfields. Covers entire playfield so it will help to smooth out the raised inserts.
