Hello everyone! Question;
I've have a Popeye pin, and have recently been having an issue with the bluto ball lock about 90% of the time..
Once the first lock is activated, and a ball is hit in, it locks the first ball no problem. Next, if a subsequent ball is hit in the bluto scoop WITHOUT lock being lit, it will do as its supposed to, which is whistle and kick a ball back out (not locking it as the second ball locked), but most of the time (90% or more) it will ALSO whistle a second time and pre-maturely kick out the FIRST locked ball right after, thus putting a second ball in play, and no more first ball locked. One of the two balls CAN be allowed to drain, not affecting game play.
Now if the first ball is locked, and then lock is lit for the 2nd, and a 2nd ball is hit in the scoop, it locks it no problem without kicking it out, and then once multiball is lit and the 3rd ball is hit in the scoop, it starts multiball with no problems.
It only does this on the SECOND ball hit into the scoop after ball 1 is locked without lock being lit, it will not do this on the 3rd ball hit into the scoop after 2 balls are locked.
Now... all the switches on the center scoop are micro switches, and all seem fine when physically tested, and (there are 4) the issue is that they almost impossible to check without removing the scoop assembly. Any ideas? I think that it might be a sticking switch that aligns with the SECOND ball position in the "holding area" of the scoop above the coil gate.
