(Topic ID: 105283)
Popeye ... owners club
By skygualker
  • 431 posts
  • 76 Pinsiders participating
  • Latest reply 3 hours ago by the4horse
  • Topic is favorited by 32 Pinsiders
There have been 148 images uploaded to this topic. (View topic image gallery).
There are 431 posts in this topic. You are on page 9 of 9.
#401 10 days ago
Quoted from McPin54:
Yes, I repaired th original MPU. Original works perfectly
So the MPU from Rottendog had an issue? Rottendog have any solution for this?
I too tried to repair my acid eaten original MPU board but I just got tired of it know ing it might screw up again so went Rottendog.
UPDATE: Tried each hole on the wheel tonight. Each labeled hole recorded on DMD properly with Rottendog MPU board in the game.
Maybe my ROM Version is newer or something different between our two Popeyes?? I dunno.
#402 9 days ago
I’ve just joined the club!
My example is rough but the playfield is pretty good. What parts are available/unobtainable? I need a new left ramp, boat stern, plastic set, scoop, decals etc
#403 9 days ago
Quoted from CUJO:
I had a bad MPU. Rottendog is great, they replaced it but I have just been using my old one.
Glad yours is working!
#404 6 days ago
Been tearing down my Popeye and my center scoop is awful! Does anyone have a used scoop in better condition than this?
8770106B-ED9A-4C3C-96D3-7146B098E432 (resized).jpeg966EF2BF-66DC-4E2A-AF02-47264511894B (resized).jpegC98B168E-4119-4F2E-8D1B-E39052F6F1C8 (resized).jpeg
#405 6 days ago
Wow, Can you use a grinder and smooth some of those welds down and shine it up?
I'll look at Allentown show. Sometimes the parts guys have stuff like that.
#406 5 days ago
I got one of those clear animal ramps from Pinball life - has anyone ever replaced one of these ramps? I know at least one person in the thread did. Do I have to unsolder every connector on each switch and light in order to swap these ramps? Because yuk.
#407 4 days ago
Anyone else experience a problem with the center scoop not registering locks and spitting the ball out right away. It seems like if I fire the ball into the scoop at higher speeds it spits it right out instead of registering the lock. Wondering if this is common and if there is a fix.
TIA
#408 4 days ago
Quoted from Murphelman:
TIA
It might be one of the sub-miniature switches (5647-12693-25) although if one of them wasn't registering it might not spit the ball out at all. I had to replace a couple of mine and it's a cheap and easy job. Usually when you manually activate them they should make a click noise...mine didn't. Good Luck!
#409 4 days ago
Quoted from alexmogil:
Answer: yes, yes you do have to unsolder and resolder them. And it's not super fun but it's also not super terrible.
I still haven't decided on what color bulbs for the animals. I probably should have considered a blue ramp instead of red.
#410 4 days ago
Lools good. The Red looks good with red wheel and the other reds on the game. I wouldn't beat yourself up on the color.
Color dmd on this game is a must. One of best games for color DMD
Put cool white LEDs under sweet pea stars. Makes a noticible difference
Great job!
#411 4 days ago
Put cool white LEDs under sweet pea stars...makes a noticible difference
Great job!
#412 4 days ago
Answr: yes, yes you do have to unsolder and resolder them. And it's not super fun but it's also not super terrible.
I still haven't decided on what color bulbs for the animals. I probably should have considered a blue ramp instead of red.[quoted image][quoted image]
Thanks for posting ...I was initially thinking Red, but Blue is still in the running. How close does the Red match the Skill shot wheel red ?
#413 3 days ago
Great job!
I did a $500 order from Comet and I forgot to order natural white 44's. I was kicking myself. But yes, thanks! It does look good! I will probably next get a spotlight for the wheel to make it just a bit more viewable.
Quoted from Ive:
It matches it quite well, except the wheel is opaque of course. I don't think you can go wrong with any of them, there was an earlier post with yellow that looked really sharp!
My next decision is gonna be the animal lights. I might keep them blue (little too bright), might make them red again (get lost in the ramp color), or I might put bendies on them and point them at the animal decals as little spotlights.
Anyone on the fence about ColorDMD should no be on the fence. It is magnificent. I went with LED and it has a factory look and fits perfectly. taxman you did an exceptional job.
#414 3 days ago
Does anyone know how to remove the top part of the wheel? I’d like to clean the track on the playfield under it
#415 3 days ago
Just start unscrewing from the top
#416 3 days ago
Yes but when I get to the part with the circles it doesn't come out?
#417 2 days ago
I shopped out about a month ago and don't remember anything crazy going on. Maybe some screws on the bottom??
There may be a C clip but its pretty easy.
Good luck. Take a pic of the area where you are at and having a trouble.
#418 2 days ago
The piece of metal with the circles is the part I can’t get off. Someone here must know how
#419 2 days ago
Quoted from allsportdvd:
Been tearing down my Popeye and my center scoop is awful! Does anyone have a used scoop in better condition than this?[quoted image][quoted image][quoted image]
That whole piece is unobtainable. I looked everywhere. I thought mine and as bad but after seeing yours I fell better lol.
#420 2 days ago
Hello there!
I'm about to finish my Popeye, just done all the electronics, and now I'm having problems with the Bluto ball lock :/
Looking at your pictures, I see my pin has a different ramp, or is missing a plastic cover.
I'm using alexmogil picture BTW, I hope you don't mind
All of you have a blue plastic ramp at the upper left corner, like in the first picture from Alexmogil.
But in my Popeye, the ramp is made of polished metal, am I missing a plastic cover? or have I a different version?
#421 2 days ago
I think I read earlier in the thread that some earlier models of the game had a metal feeder ramp into the animal ramp. That’s all!
#422 2 days ago
So they went to a better looking blue plastic ramp, and to an uglier 2D Bluto face hahahahahaha
#423 2 days ago
Quoted from waffen_spain:
Anyone have the white plastic ramp installed?
#424 2 days ago
The piece of metal with the circles is the part I can’t get off. Someone here must know how[quoted image]
I'm pretty sure mine just lifted out. Anyone else confirm?
#425 2 days ago
Must be an issue here. I just did an entire teardown and mine came without any problems.
#426 1 day ago
So it's supposed to just lift out?
#427 1 day ago
I may be mis-remembering but from what I remember is just lifts out. There may have been a C clamp holding it but thay was it.
#428 1 day ago
I agree
#429 1 day ago
Hello there!
Yep - some machines have the metal ramp.
The promo flyer shows it as metal. I'm guessing the early production machines had metal and they then switched to blue plastic. See the blue plastic much more often.
#430 14 hours ago
I just took mine out to clean it and it lifted straight up.
Also just got done with clean/rebulb/rerubber/re-plastic post job, added a spotlight to the prize wheel and I really, really like it!
IMG_20190420_185450 (resized).jpgIMG_20190420_185501 (resized).jpgIMG_20190420_185455 (resized).jpgIMG_20190420_185505 (resized).jpg
#431 3 hours ago
Also just got done with clean/rebulb/rerubber/re-plastic post job, added a spotlight to the prize wheel and I really, really like it![quoted image][quoted image][quoted image][quoted image]
Great idea adding the spotlight...the game really needs it!
3,500
Denver, CO
