(Topic ID: 163443)
Pop bumpers stuck
By kse001
7 years ago
  • 5 posts
  • 3 Pinsiders participating
  • Latest reply 7 years ago by kse001
    #1 7 years ago
    I'm working on putting a WPC-95 machine back together and two of the pop bumpers are not behaving. In coil test, they fire but then the pops are stuck in the down position. The problem is mechanical, since I can kill the power and the bumpers stay down and a gentle touch on either bumper (with power off or on) causes them to return to the normal position. I've examined them pretty thoroughly and I can't seem to find anything rubbing or binding.
    The bumpers were completely cleaned/rebuild during the teardown, so switches are gapped properly and centered properly, and no flattened plunger/stop or bad sleeves here. I understand that parts can get magnetized, as discussed in this similar post from a couple years ago https://pinside.com/pinball/forum/topic/sticking-pop-bumpers. What I'm wondering is whether that could still be the case here given that I've held very small screws, washers, etc by both the coil stop and the plunger and neither seem to show any magnetic attraction. I have the driver board out now and am waiting on some replacement electronics, so I can't easily test solutions but wanted to see if there were any thoughts so that if I do have to order some new plungers or whatever I can do it now rather than waiting.
    Thanks for any experience you can share.
    Kyle
    #2 7 years ago
    If you slowly press the rod/ring assembly down do you encounter noticeable drag? Will it stick doing this?
    Try partially loosening the three locknuts that secure the frame to the field and also the two nuts securing the rods to the plunger. Wiggle it around a little. See if the rod/ring assembly still sticks. If it doesn't, retighten the three nuts holding the assembly then the two for the rod/ring assembly.
    Fixed? Different? No change?
    #3 7 years ago
    Thanks for the response. No, I don't notice any resistance at all when I manually operate the bumpers, and I cannot get them to stick when I manually push them down either.
    During troubleshooting I had removed one of the brackets to check the magnetism theory, and when I reassembled it I jiggled things around a bit to make sure nothing felt like it was binding, but I didn't leave anything loose. I'll try loosening the nuts a bit and see what happens when I get the PDB back in the game and can test it properly.
    #4 7 years ago
    The two nuts that secure the ring to the plunger are probably on too tight, causing the bind. Loosen them both. Then tighten until they just stop with normal twisting. That is all they need.
    #5 7 years ago
    So, after disassembling and reassembling the pops several times, I noticed the coil sleeves I had received were longer than usual. I didn't see how that would interfere, but lacking any better ideas I trimmed about 1/8" off. After doing so all of the pop bumpers tested just fine. Never ran into this before so I thought I'd post in case it helps someone else someday.
    This page was printed from https://pinside.com/pinball/forum/topic/pop-bumpers-stuck and we tried optimising it for printing. Some page elements may have been deliberately hidden.
