New! Dark mode!
(Topic ID: 270235)
Pop Bumper stopped working! Bally Kiss
By Parasite68
4 months ago
  • 23 posts
  • 7 Pinsiders participating
  • Latest reply 4 months ago by Parasite68
#1 4 months ago
Hi.
One of my pop bumpers stopped working. I tried cleaning the switch contacts, but still nothing. The solenoid engages during the solenoid tests. Any thoughts or suggestions? Please help!
Thanks in advance!
#3 4 months ago
Quoted from Parasite68:
Hi.
Thanks in advance!
if it pops in coil test then it is likely a switch issue. Get the manual out and find the switch matrix page to reference from. Put the game in switch test and check the pop bumper and other switches in the same row and column as the problem pop. Note if all switches in one row or column are not working or if just the pop is not working.
If its just the pop check closely under the PF around the pop. no broken wires off of the switch etc.
If an entire row or column is out look for a broken wire under the PF and check the MPU plug for connector problems. The top right plug on the MPU is playfield switches.
#4 4 months ago
Clip one leg of the the round ceramic disc capacitor on the switch for that pop bumper and see if it comes back to life.
#5 4 months ago
I’ll also note that sometimes a broken wire might not be on that exact switch but on another switch in the same column or row, even though that other switch is working. So, it can’t hurt to take a quick look at the others.
#6 4 months ago
Quoted from barakandl:
One other switch isn’t working. It’s the letter “I” at the top of the playfield. Not in front of the machine right now so I can’t do a switch test... How involved would it be to replace the switch if needed?
#7 4 months ago
Quoted from vdojaq:
Are you talking about the little resistor or the red thing next to it?
#8 4 months ago
#9 4 months ago
Quoted from vdojaq:
Ahh... ok!
#10 4 months ago
Quoted from vdojaq:
So, snipping this would cause it to work again?
#11 4 months ago
Quoted from Nokoro:
If I’m reading this chart right, the right pop bumper and the “I” rollover is in the same row. So should I be looking for a clipped wire on one of the components in that row???
3ABC6B2B-CF47-42BC-B53C-BEA9B7FD6E74 (resized).pngD1802376-345E-4311-8A91-4EAE5701C287 (resized).png
#12 4 months ago
Is anything else in that column not working? Like the spinner or the "A" target?
#13 4 months ago
Quoted from vdojaq:
Now that I’m thinking about it, the left spinner wasn’t registering points and the a didnt on the last game we played this evening.
#14 4 months ago
Quoted from vdojaq:
which wires would I be looking for?
#15 4 months ago
Check the wire color in common to all non working switches. Follow it along the playfield looking for a place it is broken loose. Check in the backbox connector for a broken female crimp contact or a broken solder joint on the connector header pin.
#16 4 months ago
Thanks! I actually checked all connections at the mpu and they were all good earlier! Now I’m focused on the bottom of the PF! Thanks!
I’ll report tomorrow with what I’ve found!
#17 4 months ago
Yeah, likely a broken wire somewhere along that column. Some switches may be working while others may not, depending upon where the wire broke. And, remember, it is possible for the wire to have broken on a switch that is still working but cause problems for other switches.
#18 4 months ago
I checked and nothing in the column is working. There’s two brown wires with a white stripe connected to all on that column. None of them are loose. Does that mean the wiring itself is bad or is it something else?
#19 4 months ago
You want to visually inspect the wire from the connector in the back box to the switches on the playfield. What happens is a wire can get pinched or even cut. Trace the wire(s) looking for any sort of damage to it.
#20 4 months ago
whens the last time the connectors were changed?
#21 4 months ago
Okay. So I dig deeper and found the brown wire on the connector became unseated (apparently yesterday when I was fiddling). I also had a couple of blown fuses this morning. Everything is now working except for the right pop bumper. I’m guessing now that it’s the switch???
#22 4 months ago
Quoted from wdennie:
The connectors were changed out during this current restore!
#23 4 months ago
I knew these machines were delicate, but mine is extremely delicate! I’m afraid to fart around it now!
$ 50.00
$ 99.99
Displays
PinballSolutions.eu
nvram.weebly.com
