(Topic ID: 17357)
Pop bumper mounting screws - countersink?
By SDobek
11 years ago
  • 6 posts
  • 5 Pinsiders participating
  • Latest reply 11 years ago by PNBLWZD
#1 11 years ago
I'm populating a new playfield for a Monopoly and I'm at the point where I need to drill through and mount the pop bumper twist shank screws. Does anyone have advice on a good bit to countersink these? They are two small for a spade bit and all of the countersink bits I have seen have a sharp taper. Do I even need to bother countersinking it? I notice that the original board had them recessed so figured I should copy. thanks -stan
#2 11 years ago
You cringe if you saw them doing it at the factory.
Drive them in with a big hammer.
LTG
#3 11 years ago
Big hammer... your right I would cringe. There was no artwork smashed underneath the head of the screw so I figured they did something to countersink the hole a little first.
#4 11 years ago
Quoted from SDobek:
Nope. The factory simply smashes them in. Under a pop bumper, I hammer them close, then use a nail set or similar to punch them down the rest of the way. Try to minimize PF flex.
An exception would be the same twist speaker screws used on Monster Bash to hold the Drac motor assembly. Since at least one head is really, really close to an insert, you would not want to fracture the wood there, yet the screw needs to be flush as it is not hidden by a pop bumper skirt.
Chris Hibler - CARGPB #31
http://www.Team-EM.com
http://webpages.charter.net/chibler/Pinball.htm
#5 11 years ago
could you use a brad point drill bit the size of the head of the sss with some sort of stop on the drill bit to prevent it from countersinking further than 1 mm?
#6 11 years ago
Either a hammer and a drift punch, or if you dont want to pound on it take a drill motor with a deep socket and draw it down from the other side with a free running nut and a couple of washers
6,200
Seaside, OR
Metal-Mods
$ 18.95
$ 1.25
Mitchell Lighting
$ 12.95
$ 36.95
Mitchell Lighting
Vienna, VA
3,400
San Diego, CA
$ 40.00
3,200
Brooklyn, NY
$ 17.00
Nordic Pinball Supply
This page was printed from https://pinside.com/pinball/forum/topic/pop-bumper-mounting-screws-countersink and we tried optimising it for printing. Some page elements may have been deliberately hidden.
