If a ball activates a pop bumper switch and another pop bumper fires, what is going on? (Just turned it back on after restoring it). Thanks.
Quoted from Johncare07:another pop bumper fires,
That one has a switch that is too sensitive.
Adjust the leaf blade switch for it below the playfield.
Turn the game off. Lift playfield up and lean back. See the leaf blade switch ? The long one with the plastic spoon is pushed by a plastic rod coming down from the pop bumper skirt. This plastic spoon should be clean, ( not worn on older games ) well centered on the rod, just resting on it, not pushing it up. The shorter lower leaf blade switch should be close enough so the slightest ball hit triggers it yet vibration doesn't set it off. A little adjusting/tweaking, and you'll be fine.
This page was printed from https://pinside.com/pinball/forum/topic/pop-bumper-help-please-taf and we tried optimising it for printing. Some page elements may have been deliberately hidden.
