(Topic ID: 288838)
pop bumper electrical question
By mark532011
1 year ago
  • 7 posts
  • 4 Pinsiders participating
  • Latest reply 1 year ago by TimMe
#1 1 year ago
I have a question on my Ice Revue. I am trying to understand how the device works and I am looking at the pop bumpers.
All of the pop bumpers are wired similarly, what I don't understand is how the bottom switch works. There is only a single (black/orange) wire to it. In other EM's, the base has been wired to ground so electricity can flow, but this one doesn't seem to have anywhere for it to go.
When contact is made, is electricity supposed to flow from the brown/orange wire, through the closed switch, to the metal mount, up through the screws and onto the plate at the top and finally out through the red/white wire? that seems iffy.
#2 1 year ago
I have seen this also, and initially it looks like a solder tab is missing, the pop bumper spoon has continuity to the top leaf blade.
#3 1 year ago
Quoted from Rikoshay:
Ahh so the screws are providing ground to the cup leaf?
#4 1 year ago
Yes, the two long machine screws running through the switch stack are conducting power from the top switch blade to the spoon (cup) blade. Note that the top spacer on the switch stack is metal, not phenolic, which is what makes the electrical connection between the top switch blade and the screw heads.
The electrical connection through the hardware itself is a good reason to always make sure these two switch stack screws are down tight on every pop bumper switch assembly. You can tighten these screws in place by putting a 1/4" wrench on the nut on the back side of the mounting bracket to keep the nut from turning, and then tightening the head of the screw with a flat-blade screwdriver while holding the nut in place.
- TimMe
#5 1 year ago
so....replacing one of the cups with a plastic one is not a good idea?
#6 1 year ago
Quoted from TimMe:
- TimMe
So good to know if I ever encounter this, thanks!
Quoted from mark532011:
Hah! Didn't even notice, great point.
#7 1 year ago
Only on a Bally!
$ 5.95
The EM Scientist
$ 7.49
