(Topic ID: 213670)
Pop bumper coil question, Elvis
By Arcade
  • 8 posts
  • 3 Pinsiders participating
  • Latest reply 3 years ago by zacaj
#1 3 years ago
On to my next issue. Just noticed my top left pop is not popping.
I put the game in switch test and it registers a hit.
Start a game and hit the switch, it will make the game noise letting you know it was hit, but still no pop.
Fuse is good and other pops work great.
I then checked the transistor Q9 by grounding it manually and the pop coil fires every time with a manual grounding.
What should I try next?
#2 3 years ago
Does it fire in coil test?
#3 3 years ago
Quoted from zacaj:
I will check.
#4 3 years ago
Nope. In coil test it does not fire.
The other 2 do.
#5 3 years ago
You didn't check the transistor. You checked transistor legs to and including coil wiring.
I'd replace the transistor. If that doesn't do it, something upstream from it isn't working.
#6 3 years ago
Thanks Loyd.
Both of those were my guesses.
But I’m the past if I grounded a Q9 or the like and the coil fired it was usually not the transistor.
I’ll change it and see.
BTW, still loving our AFMr LE
#7 3 years ago
No change with new Transistor
#8 3 years ago
Quoted from Arcade:
Probably something else on the board that drives the transistor then. Work backwards up the chain
