New! Dark mode!
(Topic ID: 206424)
Poor man's Stadium lighting
By Fytr
2 years ago
  • 849 posts
  • 162 Pinsiders participating
  • Latest reply 21 days ago by AUKraut
  • Topic is favorited by 274 Pinsiders
There have been 305 images uploaded to this topic. (View topic image gallery).
There are 849 posts in this topic. You are on page 17 of 17.
#801 34 days ago
Question for the group, I build my setup based off AUKraut minus the wifi piece. The problem I am having is when i hook the controller clips to the GI the lights start flashing and the board unit heats up to the point I cannot touch it. Any ideas where to look on this? i have them in my Iron Maiden
#802 34 days ago
Installed a set of the portable rails from post 773 on my WCS. Took the pics with my SLR set in manual mode with identical exposure to really highlight the difference!
#803 34 days ago
Quoted from Swoods5688:
Definitely sounds like you have something not wired correctly. Can you take a pic of how you have the GI driver part wired up?
#804 33 days ago
Quoted from AUKraut:
This is my set up
#805 32 days ago
That looks right. Are you sure you hooked the wires from J1 to a GI light socket and not an insert or flasher?
#806 31 days ago
Quoted from Bos98:
So I took a few things from this thread and made my own version.
This uses the dual channel relay a RGBW controller for GI lighting and using the second channel UV flashers.
At this point there are enough links to parts so here are some photos and how it’s wired.
On the left of the relay with 6 outputs I daisy chained the COMS together and ran a jumper from COM2 to the DC+.
I then spliced the Black wire of a RGBW jumper and hooked the one side to the DC+ and one to NO1
I attached a long extension wire from DC- to use as a connecting point for the many grounds.
I then took a MALE and a FEMALE 12V plug and hooked the + to the DC+ and the - to DC-
The DC+ is also where I connected the other end of the BLACK wire coming from the RGBW controller.
I plugged the MALE power run in to the RGBW controller and left the FEMALE plug to attach to a 12V power supply of your choosing.
Then attach a set of wires as a trigger. I took the red to IN2 in this example and the black to the DC-. Then attach alligator clips to the trigger wire.
If you want UV flashers simply add another trigger and a second setup on the other channel similar to this.
Set the black jumpers to HIGH to have the lights turn on with the game. If you set them LOW the lights will turn on when game lights turn off which is probably not what you want.
Follow the other guides on construction setup of your light strips.
Hope this helps anyone else who was trying to get RGBW GI with WiFi control + UV Flashers on a single relay.
I have bench tested this with no issue. Just waiting on glue to dry before I take this to a machine.
I knows it’s not pretty but it was a first run. I am sure I will come up with a better hookup on the next one.
[quoted image][quoted image]
So this particular relay will work with a lower voltage signal from the GI to turn on and off? Even though it is a 12 volt relay?
#807 31 days ago
Quoted from Fytr:
Both to the same socket, one for each wire connecting to the socket. Careful!
Hooked up two white led sets to my two data east pins and they work great. Thanks!
Now I tried doing a rgbw set but the remote dimmer does not work and lights are not bright. Does this driver not work for RGBW? Or maybe it needs to wired differently?
#808 31 days ago
Quoted from Kawydud:
Yes
#809 31 days ago
Quoted from Bos98:
Does this method control gi lighting going off and on with game for both the RGB and W leds?
#810 31 days ago
Quoted from Roy6585:
Yes
#811 30 days ago
Thank you!
#812 30 days ago
is there a way to use the power of the machines power board? Like i do with http://www.speakerlightkits.com/ ?
#813 30 days ago
Quoted from Prodoshi:
Sure, several 12V power supply boards available at Pinballlife that you can use as a 12V power source for the lights. Here is an example I've used for Spike mods: https://www.pinballlife.com/accessory-power-supply-for-stern-spike-spike-2-system-machines-backbox-mounting.html
#814 30 days ago
You guys have some Crazy skill. Appreciate the knowledge sharing. Thanks.
#815 30 days ago
thanks alot!
#816 30 days ago
Quoted from AUKraut:Correct: on the same socket, and depending on the pin the orientation will matter, and on others it won't. Putting the black to the outside of the socket (if it's a bayonet 44/47 type) should make it work.
Any help would be appreciated not sure if this will work with RGBW. I don’t want to fry the machine.
#817 30 days ago
Quoted from Blackzarak:
Any help would be appreciated not sure if this will work with RGBW. I don’t want to fry the machine. [quoted image]
That will work! Keep in mind you can test it at the bench, just find you a 5V wall wart. Hook up the RGBW and power that up. The RGB should light up but not the white. Test the red/black to the wall wart and the white should flash on when they touch.
One thing to keep in mind is that you really need to stabilize the 5 RGBW connectors you soldered on the left so they never can touch. When I build one of these I use 2 of the RGBW connectors like you show on the left, then all soldering is done on wires and PCB only by connecting them to the driver module.
#818 30 days ago
So I try hooking it up, but I was concern after I notice my GI on the Playfield got a lot brighter Don’t know if that’s normal? Also notice that connecting only the positive alligator clip lights up the white with out connecting the negative.
If I reverse the connection on the bayonet with the alligator clips it flickers My GI on Playfield off !
Are the alligator clips supposed to be on certain connections on the bayonet ?
Sorry hate to sound like a rookie what’s a wall wart??
#819 30 days ago
the plug that goes into the wall outlet for power aka "AC Adapter"
#820 30 days ago
No, the GI brightness should not change. The red alligator clip should go to the center contact of the LED socket.
Best bet is to try and bench test it for now using a 5V AC adapter (aka wall wart) as the trigger source to make sure that the module and wiring are working. Visually from your pic the wiring looks correct. Out of the dozen or so of these modules that I've bought I have had one or two that wouldn't work correctly.
#821 29 days ago
Its works fine, just was concern because it made the GI brighter which didn’t seem normal as if was producing more voltage to the GI. Any idea why would this happen I. Does it matter if the GI is higher than 5 volt ? Like 6.3 volt I belive my HOH Elvira is different
#822 29 days ago
Stern's GI being 6.3V is fine and normal, I just mentioned 5V for testing as most have a 5V AC adapter available versus having a 6.3V adapter.....
I haven't notice it raising the GI brightness with the ones I've built and installed, so really don't know
#823 29 days ago
Just added some lighting to my Rob Zombie. I used a 3/4" aluminum channel that I 3D printed mounts to go on top of the rails. I also 3D printed some apron mounts for additional lighting. What a huge improvement over a dark original playfield. First picture is stock.
20200923_211833 (resized).jpg20201009_182520 (resized).jpg20201009_182601 (resized).jpg20201009_214001 (resized).jpg20201011_160854 (resized).jpg20201011_160911 (resized).jpg
#824 29 days ago
Just wanted to say thanks to everyone on this thread, especially hurryuppinball for the how-to videos and aukraut for making the GI relay so simple.
I made one set of these for my High Speed restoration and still have all parts needed for a second set. Everything required for 2 sets was less than $100. It took me about 2 hours to make them.
That said, if anyone reading this thread is wondering if they would be able to make these, the answer is yes! Seriously, don’t pay for the PinStadium ones. It’s great that they came up with the concept, but $300 a set is absolutely criminal. I used to have a MBr with a set of the real ones that were purchased by a previous owner. This set I just made is basically identical.
I’m certainly no electronics wizard and if I can do it, you can too!!
B6E9A4EB-DBED-4A88-8E2F-190EDBB62B67 (resized).jpegB7EAC40C-91BF-42DE-955B-6D354260FB5E (resized).jpegF61783CC-A64C-41BB-BB7A-F8669EE4A5A4 (resized).jpegEE6BB684-1B2D-440B-BD10-33131748DFFE (resized).jpeg298F8117-6D16-49CF-AFA4-EDF5E7FB2399 (resized).jpegC18BADA7-3A36-4723-91BF-6D87F4FF470A (resized).jpeg
#825 29 days ago
Quoted from Bellagio:
[quoted image][quoted image][quoted image][quoted image][quoted image][quoted image]
Awesome!!! Great job!!!
#826 29 days ago
Very nice job and thank you for sharing!
I have been following this relay thread but, to be honest, found it very confusing.
I already have the LED strips installed (always on through service outlet) but would like to try wiring in a relay, so please can you share a link to the relay and where it was purchased?
Also, I assume the red/black wire from J1 is going to a GI lamp? if yes, is it red to the center and black to the outside?
Thank you.
Roger
#827 29 days ago
I have a thought: seems like purchasing the materials for a light set requires the purchase of enough product to make at least two sets. Would there be any interest in folks offering up their leftovers or partnering when purchasing? I only have one game that I’m interested in adding lights right now, so buying leftovers or splitting with someone is very attractive.
Just a thought.
#828 29 days ago
Quoted from rogerdodger:
Thank you.
Roger
Here are the relays I bought:
amazon.com link »
Correct, J1 is the trigger. I just picked a nearby GI lamp and connected the black alligator clip to the ground and the red to the other. Most important thing is to make sure it’s a GI lamp.
#829 29 days ago
amazon.com link »
Thank you.
Much appreciated.
Roger
#830 29 days ago
bellagio, dude! Nice work, this pic is gold and put me over the top to order the parts to make a set. Thanks!
#831 28 days ago
They look great and happy to help. I’ve built close to 30 of these and have switched over to the WiFi receiver and it works very well and gives access to 16M color choices. All my pins and lights are connected to Alexa and since it remembers the last setting, I just tell Alexa to turn on the pins and never have to touch the remote unless I want to dial in the colors on my phone. I ordered a bunch of light diffuser covers and will be upgrading my 7 pin lineup. Big thanks to AUKraut for all his guidance and hunting down parts to order. I just installed a set in STh along with the UV light kit and love it. These have helped so much with streaming as well.
#832 28 days ago
Quoted from HurryUpPinball:
They look great and happy to help. I’ve built close to 30 of these and have switched over to the WiFi receiver and it works very well and gives access to 16M color choices. All my pins and lights are connected to Alexa and since it remembers the last setting, I just tell Alexa to turn on the pins and never have to touch the remote unless I want to dial in the colors on my phone. I ordered a bunch of light diffuser covers and will be upgrading my 7 pin lineup. Big thanks to AUKraut for all his guidance and hunting down parts to order. I just installed a set in STh along with the UV light kit and love it. These have helped so much with streaming as well. [quoted image]
Impressive! How did the diffuser covers work out?
#833 28 days ago
Quoted from Gogojohnnyquack:
You bet! Getting these lights to switch on/off with the playfield GI was what held me back from making them long ago. aukraut came up with the simple relay design and it works perfect!
#834 28 days ago
You’re videos were great, I played them on my iPad while building the rails and everything worked perfectly!
#835 28 days ago
Quoted from Fytr:
I originally found them, they are for sale here: https://www.solidapollo.com/78-Milky-LED-Strip-Diffuser/Cover.html
In terms of working out: So so......They work, however keeping them attached and looking neat at the same times tough. You have to use glue to keep them attached. I'm still searching for a better solution.
#836 28 days ago
Here’s a question for anyone that’s using a relay:
I didn’t want the relay just laying in the bottom of the cab unprotected so I put it inside this small electrical box. What are you guys doing with yours?
For my next one I’m thinking about sealing the relay in heat shrink after I wire it up. Anyone think that could cause a problem or have any other ideas?
#837 28 days ago
That’s one of the reasons I removed the two blue terminals and soldered the wires on instead: to make it easier to use heat shrink. No issues with it so far.
#838 28 days ago
Gotcha, good thinking! I’ll be doing that on the next one. I’ll probably also re-do this one. The heat shrink gives it a cleaner look.
#839 24 days ago
amazon.com link »
If you get this kit the large ones fit over nicely if you remove the blue clamps
#840 23 days ago
I ordered a set of the diffusers and placed a very tiny drop of superglue every 6 or so leds (top and bottom of the strip) then removed the adhesive backing on the diffuser, attached it, then took a spare 90 degree bracket placed it over the diffuser. I taped it in place to put pressure on the adhesive and the glue and left it overnight. It is mounted on the strip very well and doesn’t move and there is no mess. I barely touch the strip with the superglue nozzle. I placed the glue in the gaps between the lights. I did lay the diffuser roll out flat and placed some weight on it and let it sit overnight. When the diffuser is shipped, it is rolled up. It is important to lay it flat for at least a day so it can flatten out. Here is a pic of the diffuser after it dried for a day.12DA33D5-BD15-4CDD-92B5-DADEE7A15DC5 (resized).jpeg I have also posted some pics of my game with and without the diffuser. The first two are without and the second two pics are lights with the diffuser. It doesn’t eliminate the stripes but it does tone them down a good bit. This is with the lights at full brightness for colors and white lights. Thanks again AUKraut for the link to the diffuser.
84CB18C5-68E6-4637-B4BD-2E59BE487D69 (resized).jpeg24635743-2813-4F7C-B7EE-D98774075201 (resized).jpeg9C8D9407-4F4D-4EFC-863E-0E3E00D10E7E (resized).jpegCE4F051B-2738-4F60-830C-30A7E84305AA (resized).jpeg
#841 22 days ago
I ordered a set of the diffusers and placed a very tiny drop of superglue every 6 or so leds (top and bottom of the strip) then removed the adhesive backing on the diffuser, attached it, then took a spare 90 degree bracket placed it over the diffuser. I taped it in place to put pressure on the adhesive and the glue and left it overnight. It is mounted on the strip very well and doesn’t move and there is no mess. I barely touch the strip with the superglue nozzle. I placed the glue in the gaps between the lights. I did lay the diffuser roll out flat and placed some weight on it and let it sit overnight. When the diffuser is shipped, it is rolled up. It is important to lay it flat for at least a day so it can flatten out. Here is a pic of the diffuser after it dried for a day.[quoted image] I have also posted some pics of my game with and without the diffuser. The first two are without and the second two pics are lights with the diffuser. It doesn’t eliminate the stripes but it does tone them down a good bit. This is with the lights at full brightness for colors and white lights. Thanks again AUKraut for the link to the diffuser. [quoted image][quoted image][quoted image][quoted image]
Thanks for the detailed explanation.
Would you say it's enough of an improvement to warrant the additional cost/effort?
#842 22 days ago
These also work very well for stuff like this. And a little cleaner look in my opinion
amazon.com link »
#843 22 days ago
Quoted from Fytr:
That’s a tough call. The stripes are reduced but not gone. I do like the fact that the light is diffused from the side and not as harsh for players on the next machine. It’s roughly $8 to test it out (plus shipping) so I figured I would give it a shot. I think on games with ramps and wireforms close to the lights it will cut down on striping and look better than the non-covered versions. I will add some more pics once I put them in my other games.
#844 22 days ago
I've often wondered but never tried if a simple smoothed out bead of clear silicone caulk over the LED strip would be enough to defuse the light and minimize strips? Not like you need to adjust them ever again but seems simple enough.
#845 22 days ago
Quoted from Fytr:
For me: no. You still have the striping, you lose some light intensity, and it's a bit of a pain to glue and have it look neat. I didn't try CA like HurryUpPinball did, I dislike using that stuff around pins due to the fogging effect it has from the fumes and don't know if heat from the LEDs would be an issue. This diffuser also only comes in single row width, not doubles which is all I'm using for my inside installs on my home pins.
Quoted from Yelobird:
Haven't tried caulk, but I've tried light coat of white spray paint, and heavy coats of privacy spray paint meant for windows, showers, etc. Both yielded unsatisfactory results. Nothing on the retail market I've found so far that does as well as Pinstadiums diffuser, and he has the volume to work with a plastics house to get them custom made for his.
#846 22 days ago
I think that the diffuser would be more effective if it could be mounted further away from the leds, for example if it was a convex shape and could extend from the top edge of the L-channel to the bottom, which would put it 1/4" away from the LEDs.
#847 22 days ago
Quoted from Fytr:
Seems like something like this (painted black) would be a perfect solution. I use them in my game room and they defuse the lights perfectly. Designed with the defuser removable and to fit standard LED Strips at a correct 45 degree playfield projection.
amazon.com link »
#848 22 days ago
amazon.com link »
Yes, that matches my description. It would be interesting to see how well it works.
#849 21 days ago
amazon.com link »
I bought those as well to play with. Mounting is an issue due to weight. Magnet strips will not hold up over time.
Displays
PinballSolutions.eu
$ 119.95
Allteksystems
$ 76.95
$ 139.00
$ 17.00
