Quoted from HurryUpPinball:I may play around with some different controllers (WiFi & Bluetooth) as that is an option with these lights. It’s easy to swap the sensor box. When I get a chance, I’ll be sure to post an update.
Quoted from HurryUpPinball:I have not tried installing a relay for a tie in to the GI yet. If anyone has advice on how to tie these in it would be much appreciated. I have run these independent of the GI for simplicity sake but improvements are always on my mind.
HurryUpPinball I hope I can help here....
Using your videos as a basis for the lighting rails I made, I wanted to have controllable GI lighting and WiFI control for my new lighting rails as well. I ordered the following items from Amazon:
Magic Home RGBW WiFi & IR controller:
https://www.amazon.com/gp/product/B07QG7HCZG/ref=ppx_yo_dt_b_asin_title_o02_s00
Switch Driver Module:
https://www.amazon.com/gp/product/B087F88WLM/ref=ppx_yo_dt_b_asin_title_o01_s00
5 Pin Connector:
https://www.amazon.com/gp/product/B07MNRR153/ref=ppx_yo_dt_b_asin_title_o03_s00
First, the Magic Home controller is controlled by a free app in the iPhone and Android store, and can also be controlled from a certain premium stadium lighting app as well. Plugging it into the RGBW lighting strip it has to be configured in the app as a RGB & W device type instead of as a RGB / W device type to allow the white LEDs to be controlled separately from the RGB LEDs. That took care of the WiFi App Control...
For the controllable GI I concentrated on controlling the White LEDs. Using the switch driver module, I unsoldered & removed the screw terminals to be able to solder the connections directly. I snipped the 5 pin connector white and black wires and soldered these to the J2 inputs and J3 outputs of the module, Black to positive, White to negative. I then soldered a set of alligator clips with long wires to the control input J1 of the module. I then placed this assembly inline after the WiFi module before the Y connector going to the lighting strips. I then connected the alligator clips directly to a GI socket. Works perfectly, controlling the white LEDs in the strip to match the GI going on/dim/off.
In the app I have the white LEDs set to 100%, and the RGB LEDs set to 25% in a color that enhances the look of the playfield. This gives good lighting in a darkened room and the GI dimming effect. If one really wanted they could use 4 of the switch driver modules to control all RGBW, but I found that leaving the RGB LEDs in a dimmed mode is the right mix to go with the controllable white LEDs. I've attached some pics as well as a short video of the LEDs on, then dimmed, and then back on again at the start of a game of Batman 66. Unfortunately the iPhone video doesn't capture the look as well as it looks in person.
