(Topic ID: 206424)
Poor man's Stadium lighting
By Fytr
1 year ago
  • 643 posts
  • 136 Pinsiders participating
  • Latest reply 21 days ago by jesperpark
  • Topic is favorited by 232 Pinsiders
There have been 218 images uploaded to this topic. (View topic image gallery).
There are 643 posts in this topic. You are on page 13 of 13.
#601 36 days ago
No thanks. I have a few Pinstadiums and I'm selling them. I don't need all the over-the-top flashers and I'm completely fed up with Scott's sleazy used car salesman tactics.
#602 36 days ago
Quoted from Cheeks:
Has anyone come up with a way to mount these on the sides of the playfield rather than the inside of the cabinet? It would be really nice to be able to lift the playfield without needing to remember to remove them.
I am working on it . I’m thinking like a L bracket that mounts under the playfield to an existing light screw or similar.
#603 36 days ago
Quoted from Langless28:
I was just going to say the same thing then read your post. I’m sure you can use hanger brackets from the hardware store.
#604 36 days ago
No thanks, pinstadium is overpriced crap. I hated having to remove them to lift the playfield and now I'm sure someone will figure out a way to use L brackets or something for a fraction of the price
#605 35 days ago
Someone could open source a similar device/bracket
#606 35 days ago
I'm thinking flat bar aluminum 1/8" x 1/2".
These lights are super freaking light weight so you dont need much support. Basically you can create a mount or two where it makes sense to attach on your title. The key here woud be to create a tight cradle for the light bar to sit in (maybe even add soft velcro piece in the cradle). Of course drill a hole in the bottom flat piece to mount onto where ever.
Another cool feature of aluminum being pliable is if needed you can twist the mount the get it "straight" you can. I'm actually out and about right now. I'm going to swing by home depot and see what I can find. I'm actually installing lights on a TAF right now. I do like the idea of NOT using velcro.
#607 35 days ago
Ready to experiment
#608 35 days ago
The 1/16" thickness will easily slide between the cabinet and playfield. This is great. No additional shadows or blockage/eye sores.
The plan is to mount under playfield. I believe 2 per side will be sufficient. Now to get some measurements AMD bending going. Need to ensure the base is bent at an angle so the lights run the same angle as the cabinet.
#609 35 days ago
Thought I'd post a pic of my poor mans setup. I prefer to use Gameon power and set the sensor in a gi hole that way the stadium lighting interacts with the gi so it feels like it's supposed to be there. As you can see the before pic is just gawd awful. (Previous owner added warm white leds which suck and are getting replaced with cool white). TAF is kind a night mare to play with stock lighting. The next pic is with full blue/white both @ 100%. Due to TAF having dominate blue on the 3rd pic I turned the brightness down on white and left blue @ 100%. The "chicklet" effect most people complain about is SUPER in your face at the angle the pictures were taken. Normal standing position it's no where near as bad but I plan on adding diffusers.
20190816_191329 (resized).jpg20190817_190801 (resized).jpg20190817_191929 (resized).jpg
#610 35 days ago
Quoted from CLEllison:
Thought I'd post a pic of my poor mans setup. I prefer to use Gameon power and set the sensor in a gi hole that way the stadium lighting interacts with the gi so it feels like it's supposed to be there. As you can see the before pic is just gawd awful. (Previous owner added warm white leds which suck and are getting replaced with cool white). TAF is a night mare to play like that. The next pic is with full blue/white both @ 100%. Due to TAF having dominate blue on the 3rd pic I turned the brightness down on white and left blue @ 100%. The "chicklet" effect most people complain about is SUPER in your face at the angle the pictures were taken. Normal standing position it's no where near as bad but I plan on adding diffusers.
Are these just mounted to side of cab with magnet tape?
#611 35 days ago
Quoted from woody76:
Velcro was used.
#612 34 days ago
Outwater Plastics 1935-Bk Black 3
Edit: Link removed.
#614 34 days ago
Quoted from John_I:
Outwater Plastics 1935-Bk Black 3/4" X 3/4" X 5/64" (.078") Thick Styrene Plastic Even Leg Angle Moulding 46 Inch Lengths (Pack of 3) amazon.com link »
For the record 1/2" vs 3/4" ... that extra 1/4" is annoying not to mention that's expensive considering for around $13 you get both 1/2" side rails and a can of black paint.
https://www.lowes.com/pd/Steelworks-3-ft-x-0-5-in-Aluminum-Solid-Angle/3053617
#616 34 days ago
These also caught my eye - amazon.com link »
45 degree angle for mounting the strips with a milky diffuser
#617 34 days ago
Quoted from dudah:
Some interesting choices there.
#618 34 days ago
Quoted from newovad:
Some interesting choices there.[quoted image]
Someone earlier in the thread was going to try these but they posted their results.
#619 34 days ago
Now your start to realize why pinstadium built an adjustable height and tilt bracket. Your height is going to depend on where on the pf you mount.... which can vary game to game. And your angle will depend on that location too. The glass and playfield are not at the same angle. And where you have good space on the pf will vary title to title.
And 1/8 on both sides won’t fit all cabinets. That’s probably why pin stadium opted to go for a top side mounting.
#620 34 days ago
How about this? Clear or Frosted...20", $2.90 each with Free shipping.
Designed for 5050 or 3528.
The Link is not holding, so search this 20inch 0.5m 45degree corner led aluminium profile for 10mm 5050 ,3528 strip
I have a bunch, from several years ago, and am finally unpacking stuff from before the hurricane made a mess.
There are others, they work nicely. There are different vendors which affect cost with heavier metal, Plastic as well as quality of Milky Lens,
Some, I lightly sanded to improve diffusion.
2 RGB Strips, with Controller and these mounts will run $25. Mounting? Well I tested by counter sinking some cut off screws into the cabinet,
and glued neodymium magnets to the LED Strip Housing.
I left off seeing if I could run a step up from the GI to 12V, or if I was going to stick with white/warm white in 6.3v, Enjoying I had four sections to tie in creatively.
Color bombing only looked cool for a couple days.
#621 34 days ago
I have been thinking of routing some channels in the next cab I put together for my own use. I can inlay LED strips at a 45° angle. This should allow me to raise and lower the playfield, and also eliminate the awful glare...
#622 34 days ago
Sorry. Here is 1/2" black plastic. Personally I would not use metal because it could damage the playfield if it falls for some reason. Not to mention it conducts electricity.
amazon.com link »
https://www.outwater.com/products/zz-1933/
#623 34 days ago
Quoted from OLDPINGUY:
Color bombing only looked cool for a couple days.[quoted image]
What size are those channels? I'd recommend not going over 1/2" as they just too big in my opinion.
#624 34 days ago
Quoted from John_I:
amazon.com link »
I have not seen any "plastic" channels that are not bent in some way. You might get lucky or not care about them being perfectly straight. But, if you are, then you might want to consider aluminum.
#625 33 days ago
Quoted from Lamprey:
They should be flexible enough to be held straight by the mount to the cabinet.
They should sag on their own... but not be crimped/creased to be "bent"
#626 33 days ago
They Are Aluminum and 20% Smaller than your request at 16mm or .4 inches
#627 33 days ago
Any ever thought about just spraying the ball in some fluorescent paint and adding a few black lamps so it glows, as technically all of this is so you can see the ball? instead of making everything lit why not just glow the ball hehe??
#628 33 days ago
Quoted from russdx:
Paint would wear off the ball and onto your game. Nope.
Also, the "UV LED's" don't really project much actual light.
#629 33 days ago
Here are pics of what I did using the angle from Lee Valley tools above a few posts/page. I think the ones from oldpinguy are almost identical. I sprayed black and used RGBW lights inside. I am using a Wifi controller just for color adjusting, no tying into the flashers etc. Used rare earth magnets epoxied into the cabinet in 3 places. In the pics you can see some striping but with the naked eye you can barely see any. Also the lights on vs off pics are way more dramatic than shown, my phone is 3 weeks old and is great in low light. with rail lights off the middle of the playfield vanashes
20190819_221355 (resized).jpg20190819_221535 (resized).jpg20190819_221632 (resized).jpg20190819_221652 (resized).jpg
#630 32 days ago
Quoted from jesperpark:
Here are pics of what I did using the angle from Lee Valley tools above a few posts/page. I think the ones from oldpinguy are almost identical. I sprayed black and used RGBW lights inside. I am using a Wifi controller just for color adjusting, no tying into the flashers etc. Used rare earth magnets epoxied into the cabinet in 3 places. In the pics you can see some striping but with the naked eye you can barely see any. Also the lights on vs off pics are way more dramatic than shown, my phone is 3 weeks old and is great in low light. with rail lights off the middle of the playfield vanashes[quoted image][quoted image][quoted image][quoted image]
I glad to see an example with a game I own. I'm kind of teeter-tottering on these. On the one hand a fully lit playfield is appealing, but on the other hand a well LED'd pin with added spots and zone lighting seems to give me a little better overall visual appeal.
#631 32 days ago
Quoted from Mr_Tantrum:
What you really get used to is the consistent light throughout the entire machine. I have added spots to my mmr and stnng and I am happy with the results, however data east's just seem to be dark from the start, which is why I tried out the DIY route of stadium lights. Also I find it helps dim/washout the excessive strobing flashers that the JP has. What really shocked me was this weekend I went from JP to my stern star trek and star trek looked just too dark. I always considered star trek to be way too bright, so I went back and forth and realized it's just the JP is that much more consistently bright across the entire cabinet.
#632 32 days ago
Quoted from cosmokramer:
For an even more custom look you could figure a way to allow the lights to rotate back into the groove to allow lifting the playfield, rather than having the lights permanently recessed.
#633 32 days ago
Dont disagree, but the flip side of the coin you have complete control over brightness and color. Honestly I "originally" planned on using just white due to all the pinstadium posts showing they annihilated the playfield with flooding color. I played with the brightness, then out of curiosity the color settings and found adding a scooch of a color really helps accent the playfield majority color. Using spot lights is good stuff, but you still end up with dark spots. They might not be ball trafficked areas, but being able to see all of the machine clearly is pretty cool. It does take some getting used too, I wont even lie about that. I also realize it's all personal choice but when I see peoples posts with em on full brightness it makes me think I'm playing a virtual pin, which I very very much dislike Lastly I do have to admit that adding these lights to my LOTR made a world of difference in longevity/playability. I can almost assuredly get to TABA everytime on 3 ball. Owning the machine for 6-7 years so that's huge. I never had that before. Being able to track the ball/balls seriously made a huge difference.
#634 32 days ago
Quoted from JayDee:
For an even more custom look you could figure a way to allow the lights to rotate back into the groove to allow lifting the playfield, rather than having the lights permanently recessed.[quoted image]
The physical size of those reflectors are something like 1.5"? That rail would have to be the same width .... that's a ton of real estate hanging on the side. Cool thought though.
#635 32 days ago
The suitability for stadium lighting really varies depending on the game.
For example, I went with added spots instead of stadium lights on my IMDN LE because I wanted to have the contrast between lit areas and darker areas. It really creates a mood and turned out amazing.
But on my Metallica, the stadium lighting was excellent and really made the Dirty Donnie playfield art pop, plus removing the spots over the slingshort opened up the playfield visually in a nice way.
#636 32 days ago
Ultimately for me (as some have stated) I do not like blind spots where you can't follow the ball caused by darkness (one of the reasons I cannot stand Revenge from Mars even though I absolutely love AFM). I've previously addressed the dark zone areas on my Getaway with spots and concealed Comet Matrix LED strips. I also don't have any blind spots on my JP and my current lighting is good, IMO. I have played a couple of games at TPF last year with PinStadium lighting, and from what I remember I liked some and disliked others (I really wasn't paying that close of attention at the time).
I think I'm going to need to see more in person first to decide if I want to move forward on either of my current pins. Regardless, this DIY thread is great and full of creative ideas for a home built alternative.
#637 32 days ago
There's smaller channels available. This is the ribbon I use on my remodeling projects and this is the smallest 45deg channel they make. It's still probably too big since it's the same thickness of the cabinet side but that's where a little creativity is needed and/or fabrication of a custom channel maybe?
Photo Aug 20, 10 15 53 AM (resized).jpgPhoto Aug 20, 10 18 43 AM (resized).jpg
#638 32 days ago
That's another point I did not bring up is the colored light control along with dimming. The reason I run a blue/green is that those colors bring out the blue and orange accents on the playfield. It is quite interesting to play a little to see how certain colors on the plastics and playfield, will react with the colors from the LED's then the white just adds overall Illumination. Personally I run both at 80% brightness so there is more brightness than can be had, if i took the lenses off then I would have blinding light and could join the rainbow puke club
#639 28 days ago
What are you using to glue the led-strip to the bracket? I usually just use the glue that's on the backing of the led-strip when I remove the foil and I many times have to notice that the led-strip starts to break off from the bracket.
Thanks for any info!
#640 28 days ago
Quoted from Nepi23:
Thin layer of gorilla glue works wonders. Also great for securing the connector/wires to the channel.
#641 25 days ago
Quoted from Nepi23:
The glue on the LED strips SHOULD be enough, but surface prep may help:
1. At a minimum, clean the surface of the bracket/channel with isopropyl alcohol or naptha or equivalent.
2. If the surface is really smooth, try roughing it up with some sand paper (400 grit works good) before cleaning.
3. After applying the LED strip use another bracket/channel or piece of wood and clamp it against the LED string to help it bond and let sit overnight.
I do #1 and #3 and I've never had a strip come off.
Cheers!
#642 21 days ago
Anyone made a shopping list w links to get this done?
I know people are always trying to improve, but im just needing an L- channel, white or rgb dimmable strips, and mags or velcro.
#643 21 days ago
Quoted from Dantesmark:
Check out the first post of page 1. Many links to various types of projects
$ 139.00
Third Coast Pinball
$ 14.50
PinballElectronics.com
