I am having an issue with my Pool Sharks. When I turn it on it will not kick a ball out on startup. If I push the ball out manually it will play fine until the ball drains at which point it just sits in the drain hole and not kick over. After about a half hour of being powered on it will start to work intermittenly and sometimes stay in the drain hole. By this time a little shake of the machine will make it kick over. After about another 15 min to half an hour, it will play fine with no issue. Maybe of note, the displays start out very weak and unreadable at first and eventually get better after warming up. Any thought on where to start would be appreciated. My first thoughts are one or more capacitor is starting to go out.
