Ok thanks
Quoted from dmacy:Also as a heads up to the Canadians coming for Pinfest: Eastwood is in Pottstown, Pa not too far from Allentown. If I wasn't out of town that week I'd be happy to pick one up. I'm sure some here would be willing to do that if you wanted.
Very nice thanks
Quoted from Williampinball:Hi what do you get with the HF 18lb one when you buy it ?
Thanks so much
For rusted parts I use the resin pyramids:
For polishing, I get 50 pound bags of walnut shells from the local pet shop, and add a squirt of Flitz.
Make sure your parts are clean of grease before you go and contaminate your media.
Don't bother cleaning and polishing common screws and bolts. It's cheaper to just buy them brand new at Bolt Depot:
Quoted from Williampinball:Ok thanks so much for the help ,oh do you find the tumbler load ?
Quoted from Monster_Bash:The Dillon 2001 is probably the best bang for you buck..its huge!
Big enough to put a wpc ball trought in it. I think it's about $50 more than the big HF tumble. It's bucket isn't tapered like the HF tumbler...So you can get the big stuff in there
I have no problem tumbling all the hardware form a standard tear down at one time...efficiently.
https://www.dillonprecision.com/dillon-s-cv-2001-vibratory-case-cleaner_8_8_23658.html
I've got that same Dillon. Big enough to throw in most parts.
+1 for Flitz!
Eta picture
Cool what do you think of your tumbler ?
Quoted from Williampinball:Lol loud I mean ,sorry
Depending on what media you are using, it sounds like an old garbage disposal.
You will probably put it outside if you are working in the shop at the same time its running.
Quoted from vid1900:For rusted parts I use the resin pyramids:
Where do you buy the pyramids from Vid?
And how much does it cost you for a 50lb. bag of walnut shells? Are they fine grade?
Quoted from Gatecrasher:Where do you buy the pyramids from Vid?
Welding/sandblasting place.
Harbor Freight sometimes has them, but it's hit or miss.
Quoted from Gatecrasher:And how much does it cost you for a 50lb. bag of walnut shells?
~$35. It does not have a grade on the bag, but it's like the normal "fine" walnut shell..
I'm going to have to try some of the pyramids.
I've been buying walnut shells from Harbor Freight. A 25 lb. box is normally $24.95 but with a 20% off coupon it's $20 so that's not that bad.
They sell both 24 grit "fine" and 12 grit "coarse". I've been using the coarse. The fine seemed maybe too fine but I might have to try it.
http://www.harborfreight.com/25-lbs-fine-grade-walnut-shell-blast-media-92155.html
http://www.harborfreight.com/25-lbs-coarse-grade-walnut-shell-blast-media-92150.html
Sometimes Petco has the Zilla brand walnut shells for $25 for 50lb so keep an eye out for that.
http://www.thatpetplace.com/ground-english-walnut-shells-reptile-bedding-50lb
Quoted from Williampinball:Bump ,Does anyone own a 18lb Eastwood
FYI - Canadian Tire is selling a small 5lb vibrating polisher for $99 right now. Good for small parts.
I use Zilla brand walnut shells in my tumbler. They are available at the local pet shop and less expensive than other sources. I buy the 10 qt bag for less than $10 which is enough to fill my tumbler a couple of times.
Quoted from vid1900:Sometimes Petco has the Zilla brand walnut shells for $25 for 50lb so keep an eye out for that.
I was always hesitant to buy the 24 grit because it looked too fine. Almost like a powder. The 12 grit is what my Berry vibratory polisher came with from the factory. It was originally setup to do brass cartridges for reloading.
Quoted from Williampinball:I just seen it 20% off right ?
+ 25% off coupon for 1 item, front page. Worth the drive over to Military Rd.
Around $200 CDN if they ding you coming back. But get a tank of gas, beer and groceries to offset some $$$
Quoted from Gatecrasher:They all work the same. They vibrate. I've never heard of any that didn't work well. Eastwood sells good stuff.
i have this one, use walnut media and a squirt of flitz. Works great.
Quoted from Pinballocks:Don't overload with media or your parts will bend not tumble or not tumble at all.
Do you mean overload with parts? Yes, too many parts may not allow them to tumble or move. I've never had an issue with too much media.
For 23yrs I worked with micro finishing for the automakers. Too many parts will bend them. Adding more media, (plastic, walnuts or corncob), will prevent the proper action in the bowl, also bending finer softer metals. Especially brackets, gates, or anything that can tangle. Smaller batches = more action = a better finish, faster. Most tumblers can be used wet or dry. All media will become dirty & need to be changed regularly. If your media smells moldy. Throw it away & clean the bowl completely. Always keep the lid on to prevent airborne particles & reduce noise during operation.
Quoted from Bryan_Kelly:Do you mean overload with parts? Yes, too many parts may not allow them to tumble or move. I've never had an issue with too much media.
You read my mind too.
lol
Thanks everyone for the great input I got one for the 25% off ,what's the best media for shining pinball metal parts under the PF ?
Quoted from Williampinball:Thanks everyone for the great input I got one for the 25% off ,what's the best media for shining pinball metal parts under the PF ?
i've had good luck with walnut media that i bought at the pet store, and a squirt of flitz.
25% off today at Harbor Freight. I'm going down later. I'll be getting another 25 lb. box of walnut shell media for $18.71 (regularly $24.95).
I think I'm going to try the 24 grit as vid suggested.
If you ever wanted to buy a vibratory polisher it would be a good day to also with the 25% discount.
Quoted from Gatecrasher:25% off today at Harbor Freight. I'm going down later. I'll be getting another 25 lb. box of walnut shell media for $18.71 (regularly $24.95).
Yes I just called today and they are saying the 25% is not for Canadian buyers but I also called Sat and the guy I was talking too put it though so I guess we will see if it does or not ,today I was going too add more things too my order but if it does work I will have forget about it all
When I called she told me the discount is not for Canadians thats nt right ,and Sat. When I called too order he put it though so we will have too see what happens
I just got back. They didn't have the 24 grit walnut shells but they had the resin pyramids so I got them instead.
Quoted from Williampinball:Cool does that polish they very good ?thanks for the help
here is a comparison...2 days in walnut media and very light buffing...
Quoted from cosmokramer:here is a comparison...2 days in walnut media and very light buffing...
On the right I see an original part with a protective chromate coating. On the left, coating removed.
Any of you guys using this Tumbler:
Frankford Arsenal Quick-n-Ez Case Tumbler
https://www.amazon.ca/Frankford-Arsenal-Quick-n-Ez-Case-Tumbler/dp/B001MYGLJC/ref=pd_sim_sbs_200_1
I think I read above not to buy it but it has good reviews on Amazon and is the cheapest as well.
Any users?
Quoted from mattosborn:On the right I see an original part with a protective chromate coating. On the left, coating removed.
But it sure looks good...
Quoted from Plumonium:Any of you guys using this Tumbler:
amazon.com link »
Any users?
It works ok, I have used mine about 3 years now.....there are better out there but for the price that one is tough to beat...
Quoted from Plumonium:What will a "better" Tumbler do better?
Should have clarified by better I mean larger...hard to fit some parts in this one...
amazon.com link »
Any users?
You will see my detailed 1 star review on the product page for that item. It's a gamble as a purchase as the parts are very low quality, especially the motor bearings. Unfortunately my tub cracked as well. I have now moved on to a Thumlers Tumbler and am much happier.
**edit**
It looks like it's not showing in the Amazon.CA site, here is the US link to the product with the review:
Frankford Arsenal Quick-n-Ez Case Tumbler https://www.amazon.com/dp/B001MYGLJC/ref=cm_sw_r_awd_N0w-wb8ZSBW2J
Quoted from Jarbyjibbo:You will see my detailed 1 star review on the product page for that item. It's a gamble as a purchase as the parts are very low quality, especially the motor bearings. Unfortunately my tub cracked as well. I have now moved on to a Thumlers Tumbler and am much happier.
how long before you started having issues?
Quoted from cosmokramer:how long before you started having issues?
The details are in the review, but it wasn't very long.
Quoted from Williampinball:Yes I have looked at that one they also have a 18 lb one too I am thinking the 5 lb can't really put too many in there but the 18 lb should be better right ?or is there a bigger one out there ?
Thanks for all the help
if you're going to go for the HF one, definitely look at the 18 lb capacity tumbler vs. the 5 lb version. I had a 5 lb tumbler and had issues with 3 of them (all covered by warranty) within a year's time of each one (and gave up after the 3rd one died on me. with the 18 lb version, not only does it appear to be a much nicer and sturdier unit, it runs quieter (and obviously, holds a lot larger sized items)
Quoted from j_m_:if you're going to go for the HF one, definitely look at the 18 lb capacity tumbler vs. the 5 lb version. I had a 5 lb tumbler and had issues with 3 of them (all covered by warranty) within a year's time of each one (and gave up after the 3rd one died on me. with the 18 lb version, not only does it appear to be a much nicer and sturdier unit, it runs quieter (and obviously, holds a lot larger sized items)
my next one will be the 18lb. version ... I just keep waiting for my small one to crap out... good point about the noise as well
This page was printed from https://pinside.com/pinball/forum/topic/polishing-tumbler/page/2 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
