Hi guys I am looking for a polishing tumbler or what's the best thing too use at home for under the playfield metal parts ?any ideas that people have that works well and where too buy one .
Yes I have looked at that one they also have a 18 lb one too I am thinking the 5 lb can't really put too many in there but the 18 lb should be better right ?or is there a bigger one out there ?
Thanks for all the help
I bought a Lyman Turbo 1200 from Amazon. They make two versions, the older version has a power switch, but the new one doesn't. I bought the one with the power switch. I've been happy with the unit.
Quoted from Williampinball:I had too call and they only take cards for payment
Awesome thanks
Whatever you buy, just don't buy this:
Frankford Arsenal Quick-n-Ez Case Tumbler https://www.amazon.com/dp/B001MYGLJC/ref=cm_sw_r_awd_l4N0wbY3DMA5B
Buy the Thumlers Tumbler if you want something that will last longer than you will, I love mine.
Jesse
Quoted from Mitch:what do most people use in it? Walnut median? where's a good place to get that?
Harbor Freight sells that too. I just used a 25% off coupon on some.
Here's a thread I started also
https://pinside.com/pinball/forum/topic/good-tumblers
Do you use any paste or compound with the buffing wheels or use them dry. Is there a difference between the left and right buffing wheel?
Quoted from Mitch:Harbour freight doesn't ship to Canada.
I bought a Lyman 1200 from Cabela's in Barrie. Works like a charm. http://www.cabelas.ca/product/61218/lyman-turbo-1200-pro-tumbler
Got the media (corn cob I think) from PetSmart.
The Dillon 2001 is probably the best bang for you buck..its huge!
Big enough to put a wpc ball trought in it. I think it's about $50 more than the big HF tumble. It's bucket isn't tapered like the HF tumbler...So you can get the big stuff in there
I have no problem tumbling all the hardware form a standard tear down at one time...efficiently.
https://www.dillonprecision.com/dillon-s-cv-2001-vibratory-case-cleaner_8_8_23658.html
Eta picture
I use a combo of the HF tumbler with Walnut and a 6 inch buffing wheel to finish. The cheapest place I have found walnut is at Petco. I have done like 6 machines and still have some left from the $10 bag I bought.
The key is to make sure your parts are clean before tossing them in. It saves time and materials.
Quoted from Mitch:Do you use any paste or compound with the buffing wheels or use them dry. Is there a difference between the left and right buffing wheel?
To answer your questions: yes and yes
I use different jeweler's rouge (in bar form) for different tasks.
Green for stainless steel and chrome
White for aluminum and to shine other plated parts
The wheel on the left is harder than the one on the right. I use it for a deeper cut and use the wheel on the right for more of a finishing buff.
Quoted from cantbfrank:This is what I use with walnut media and a little polish
http://m.harborfreight.com/5-lb-metal-vibrator-tumbler-67617.html?utm_referrer=direct%2Fnot%20provided
I use the same tumbler. Works well, is inexpensive, and big enough for most tasks.
Bump anyone out there owns a Eastwood 18lb metal polishing tumbler ,please let me know what you think of it .
Thanks guys
Quoted from Williampinball:Bump anyone out there owns a Eastwood 18lb metal polishing tumbler ,please let me know what you think of it .
Thanks guys
They all work the same. They vibrate. I've never heard of any that didn't work well. Eastwood sells good stuff.
I have a Berry though.
Quoted from Williampinball:I found a Eastwood 18" I think it can hold more parts ,does anyone have this one ?
It looks to be the same Chinese model as the HF one that is $129 with the coupon.
If there is actually any difference between the models, the HF one is much better rated (4 stars) than the Eastwood.
http://www.harborfreight.com/18-lb-vibratory-bowl-with-liquid-drain-hose-96923.html
Quoted from Williampinball:Cool is the big one 18lbs
Don't know about pounds. It's got a 12 1/2 quart capacity.
About the larger Harbor Freight tumbler ...
I just picked one up this weekend for $130 with a coupon. It's great, but you have to make the bowl a bit more rigid/stronger if you're polishing sharper objects (which some are in the case of Pinball). If you read the reviews on the HF website, you'll see that someone posted how to improve the bowl ... Basically paint the inside of it with truck bed liner, then epoxy in some rubber from a smaller innertube.
After seeing the bowl in person, I highly recommend you do this if you get it. HF sells an innertube with a 4" inner diameter for a couple of bucks. A can of spray on truck bed liner is about $7 from HF (he recommends the paint on type, but a can should be enough ... Just takes longer to finish the job)
Anyone have any on experience on when to use an ultrasonic cleaner in place of (or in addition to) a tumbler?
Yes I seen that too I wonder if the Eastwood is the same or better ,anyone here has one please let me know
Quoted from wxforecaster:Anyone have any on experience on when to use an ultrasonic cleaner in place of (or in addition to) a tumbler?
Ultrasonic removes grime from intricate parts.
Tumbler polishes metal parts.
Yup. One cleans.. the other polishes
Quoted from vid1900:Ultrasonic removes grime from intricate parts.
I use this one from Cabela's. I think its the same as Berry's and it's made in the USA! It is quiet and does a good job.
Here's a link to the Thumlers, the bowl is virtually indestructible and they last forever. It's a bit of an investment but worth it for me personally.
http://www.midwayusa.com/product/3143115086/thumlers-tumbler-ultra-vibe-case-tumbler-110-volt
The great thing about this one is because of the material of the bowl, its very sound deadening and you can actually have it indoors and not have it bother you.
This thread prompted me to go out and buy a tumbler. I got the harbor freight 5 lb one for $49 - 20%. I did a load of PF parts from a 1972 bally double up. Posts, screws, ,washers, springs and more. I used ONLY their fine walnut medium... no liquid polish. After about 29 hours, I took everything out and was amazed at how everything looked!
These PF parts are going to make an already nice game POP with cleanliness and shininess.
Quoted from d0n:load
Looks very nice ,anyone here have the one from Eastwood 18lb I would like too know how that one works ?
Thanks everyone
Quoted from Williampinball:Looks very nice ,anyone here have the one from Eastwood 18lb I would like too know how that one works ?
Thanks everyone
Just buy it and try it. You can always return it if it sux. I wish I bought mine a long time ago!
Quoted from d0n:Just
I would but I am from Canada and its coming from the US so it's not so easy too return it that's why I am trying too find someone that has one that can tell me
Quoted from Williampinball:Does anyone have a 18lb Eastwood tumbler
I have the identical HF 18lb one.
Works great, and believe me, I have well over 3000 hours on that thing.
This page was printed from https://pinside.com/pinball/forum/topic/polishing-tumbler and we tried optimising it for printing. Some page elements may have been deliberately hidden.
