(Topic ID: 224209)
Polishing tools for metals.
By yellowghost
5 years ago
    #1 5 years ago
    Would like to know what I need for polishing metal parts. I was at a local hardware store and they different kinds of buffers in all shapes and sizes. I think most of them were made of felt. A few made of rope. And many types of compounds.. packaged in the shape of a brick. Some were labelled fine..medium ...etc. Not sure where to begin.
    #2 5 years ago
    First, it depends on the metal and its condition.
    In Pinball, many pieces are Nickel Plated, Stainless Steel, etc.
    Once these are cleaned, one can buff the metal, but it wont replace plating, so what you buff will dull if the plating is gone, unless clear coated.
    Youll want at least a medium size motor, face mask, stitched and light stitched or half stitched Muslin wheels.
    Compounds are Brown - Course, to Green for High Polish....There is white or other colors mentioned for stainless, if you wish to try. Avoid Red at all costs.
    An Ultrasonic helps immensely.
    Harbor Freight is great for non professional, and they have a pack of wheels and rouge blister packed,
    along with affordable motors and Ultrasonic.
    Around $100-$150 for everything you need.
    #3 5 years ago
    Home Depot sells a compact buffer kit that fits on the end of a drill motor. Worked great on my rails and ramp. The other thing I did was put them in the dishwasher when I was done. But if you do that, be careful there is nothing but metal. Even welds will throw some rust
    #4 5 years ago
    Flitz works very well
    #5 5 years ago
    Quoted from wolfemaaan:
    Thanks. What department would that be located in? With the tools I reckon?
    #6 5 years ago
    Though strictly speaking not a buffing tool, a tumbler also helps a lot.
    #7 5 years ago
    Quoted from yellowghost:
    Hardware. I’m not a fan of Ryobi, but this kit works
    Here it is and these are the rails o polished
    2AFFADF0-BD83-4B72-93B6-F6A0A0664C1D (resized).jpeg2AFFADF0-BD83-4B72-93B6-F6A0A0664C1D (resized).jpegAC78D7F9-8F75-4711-A3A3-784DEB4CF6A5 (resized).jpegAC78D7F9-8F75-4711-A3A3-784DEB4CF6A5 (resized).jpegC0F0C792-DEBF-46F5-A472-E0431C07F7CD (resized).jpegC0F0C792-DEBF-46F5-A472-E0431C07F7CD (resized).jpegD3475997-DF62-4551-B5CD-49C32C330451 (resized).jpegD3475997-DF62-4551-B5CD-49C32C330451 (resized).jpeg
    #8 5 years ago
    Oh, and this is before vs after
    49ED8EF7-DD63-4FEA-B8CF-19B95A1A4C49 (resized).png49ED8EF7-DD63-4FEA-B8CF-19B95A1A4C49 (resized).png52DB9A0C-7BAA-4FF7-8CC1-4FF204FB4659 (resized).jpeg52DB9A0C-7BAA-4FF7-8CC1-4FF204FB4659 (resized).jpeg
    #9 5 years ago
    Before/after
    20180804_093019 (resized).jpg20180804_093019 (resized).jpg20180804_112059 (resized).jpg20180804_112059 (resized).jpg20180804_112119 (resized).jpg20180804_112119 (resized).jpg
    #10 5 years ago
    Quoted from Davi:
    Before/after
    Dayyaum. What did you use? Those look better than new
    #11 5 years ago
    Ingredients
    0.7 HP buffing machine.
    Saturn flap wheels to remove ball marks, surface issues.
    8" 1st stage cut wheel with black compound.
    8" 2nd stage wheel with green compound.
    8" 3rd stage with white compound.
    Lot of time. I mean LOT.
    Patience.
    Dust mask.
    Goggles.
    #12 5 years ago
    Lot of time ... How long did it take?
    #13 5 years ago
    Strongly depends of condition of original piece, but size is the biggest factor. For small parts, I would say 1-2 hours, for bigger parts, like ball guides, big metal ramps it takes 3-4 hours.
    #14 5 years ago
    Time well spent looking at those results, absolutely fantastic!
    #15 5 years ago
    Quoted from Davi:
    I thought that white comes before green for stainless? Please tell me I haven't been doing this backwards for years.
    #16 5 years ago
    Quoted from jsa:
    Green is final buffing on steel, White is polish finishing for s/steel.
    For small pieces I like to use the compounds with felt wheels on my Dremel.
    #17 5 years ago
    Quoted from jsa:
    White is after green.
    #18 5 years ago
    Consider Everbrite Coating on Buffed pieces not in contact with Ball, to keep shine, if one has buffed off the nickel plating.
    #19 5 years ago
    Quoted from Davi:
    Before/after
    What tool did this? Awesome
    #20 5 years ago
    I used Flitz on these. Just rub for a couple seconds and wipe off.
    538C9991-437D-43DB-A8CA-6C6793E4B306 (resized).jpeg538C9991-437D-43DB-A8CA-6C6793E4B306 (resized).jpegBDA63625-7121-4C50-A68D-115C6E240F4E (resized).jpegBDA63625-7121-4C50-A68D-115C6E240F4E (resized).jpeg
    #21 5 years ago
    To get a mirror shine, you need to look at the deepest scratches, and choose the right grit to remove enough metal to the scratch depth.
    Then you need to move up the grit ladder, as far as you are OK to go, before you can polish.
    You can skip the super fine sanding and go right to cutting tripoli, but if you cant hold perpendicular by hand, youll need a jig, to avoid fine waves.
    For flat objects, sometimes easier for some to anchor flat, and wrap emory in block of wood to ensure
    smoothness.
    Same as wood, just different paper.....The finer the grit, the less work on the wheel.
    #22 5 years ago
    Post #11
    1 month later
    #23 5 years ago
    Quoted from Davi:
    Bought the bullet and bought some compounds. Mine say white before green. Should I still use "white diamond "last?
    #24 5 years ago
    Usually white is polish finishing.
    However, white 'diamond' is for fast cutting on hard metals.
    "Made with fine abrasive powder that produces a final satin finish on chrome, stainless steel, carbon steel, brass, and aluminum. Also use to remove rust, scale and carbon deposits on metal surfaces."
    #25 5 years ago
    Try the order listed...green to finish, although personally, I have not tried Blue.
    Please avoid red (especially Chinese/overseas)....it can be toxic, and a pain to clean off.
    #26 5 years ago
    I noticed that using white after green seemed to go hazy again. So now I stop at green. This is piece that I've done so far. Do not own a " saturn flap" so the machine mark on the steel are still there.
    #27 5 years ago
    Either using power tools or by hand with a rag. It makes things shine.
    #28 5 years ago
    What kind of mop do you have for green?
    #29 5 years ago
    Quoted from Davi:
    Not using a mop. Its a wheel thing that inserts into a corded drill. About 2 1/2" in diameter. About a inch thick. Should I use a different wheel for every color? The wheel just looks black now. The outlane trim did not turn out too good. I guess the scratches were too deep for the compounds
    #30 5 years ago
    Not using a mop. Its a wheel thing that inserts into a corded drill. About 2 1/2" in diameter. About a inch thick. Should I use a different wheel for every color? The wheel just looks black now. The outlane trim did not turn out too good. I guess the scratches were too deep for the compounds[quoted image]
    I use following sequence:
    1. Saturn wheels to remove scratches, ball marks. 120, 240, 320 grits.
    2. Sisal Wheel.
    3. Colour Stitch Buffing Wheel.
    3. 'G' Loose Fold Buffing Wheel.
    One wheel, one compound only, don't mix.
    #31 5 years ago
    If a piece of metal does not have heavy scratches, but needs cutting, start with brown on stitched.
    The courser, gritted wheels are abrasive and used for deep scratches, pitting, etc, before getting to cutting and polishing compounds.
    One should use a different wheel, for each color.
    #32 5 years ago
    I start with actual sandpaper to get rid of deep scratches and work up in grit.
    3M green pad and metal polish get you somewhere after that. Finish up with a polish wheel or simply a rag and metal polish if you are not anal about a mirror finish.
    I said anal.
    #33 5 years ago
    Quoted from Davi:
    2. Sisal Wheel.
    One wheel, one compound only, don't mix.[quoted image]
    So once you get to "sisle" wheel, you apply compound to that? Or compound only on last wheel? They look pretty clean.
    #34 5 years ago
    Yes, black for sisal, green for color stitch, white for last one.
    That pic is about brand new wheels.
    #35 5 years ago
    Quoted from Davi:
    Oh ok thanks
    This page was printed from https://pinside.com/pinball/forum/topic/polishing-tools-for-metals and we tried optimising it for printing. Some page elements may have been deliberately hidden.
